THE THING IS LICKING - Washing Machines
  • 4,102 Answers
Hi it could be a couple of things do you have a filter at the bottom of machine at the front by the floor it will look like little flap or screw the size of a mug if their is one the remove this and clean the filter it usually get clogged with fluff from clothes.
The other thing could be the door seal this could be leaking and need replacing.
Or it could be a pipe in back of machine that the water drains from this can split due to limescale and can be replaced
Where exactly is it leaking from like door or is it coming from under neath
Posted on Apr 22, 2008
    Novelist:
  • 184 Answers
MOST OF THE WASHERS THAT ARE TICKIING ARE THE TIMER MOTOR. THE ONLY FIX FOR THEM IS REPLACING THE TIMER. I WOULD USE IT UNTIL IT QUITS. IT MAY NEVER QUIT WORKING.
A licking noise starts when the car stops in the front dash then the battery goes dead by the next morning even with new batteries
licking? my guess, clicking?
this question could get lots of banned answers, watch out.
car stated is this a World war 2 jeep (willis?)'
no year,?
no country.? they sell them and make them outside usa,
the car for sure needs service, the only thing active is head lamps
key off, (and horn and alarm)
1: does the car drive? ok.
2: do the head lights work and glow bright.
3: when you do drive is the CEL lamp in the dash glowing (check engine light)
any way its an electrical failure. if car drives ok...
my guess, HVAC controls messed up.
or a damaged Ignition key switch.
Nov 24, 2016 | Jeep Cars & Trucks
Water licking inside car
the drain on the outside of the car (engine compartment)needs a gasket put around the drain to stop this problem.A gasket like what they put around windshields ,this will solve your problem,it did mine.
Jun 10, 2014 | 2001 Mitsubishi Galant
Fordmustang1986is licking oil how ca i fix it
I was going to ask what licking meant, but I decided you mean it is leaking oil.
Where is the leak coming from ?
Feb 18, 2013 | 2000 Dodge Grand Caravan
My pool pump is licking there was only on washer i changed , but did not helped
I think you need to clarify.... Do you mean "clicking" instead of "licking", and what washer did you change?
Sep 02, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Need to figure out where water is leaking from? it's to the right of engine. Now engine light is on. can not find a mech. book to help for a 98 civic. NEED HELP :)
YOU WANT TO KNWO WHERE IS LICKING WATER THE ENGINE WELL JUST RUN A COMPRESSION TEST IN THE RADIATOR HOW THIS WORK THERE IS A TOOL FOR THIS PROSSES IS LIKE A HAND POMP YOU CONECTED TO THE RADIATOR AND LET THE PRESIOR BUIL UP HUNTIL THE PRESSIOR BUILT UP TO WHATEVER YOUR RADIATOR HOLDS THEN CHECK FOR LICKS OUTSIDE AND AFTER 10 MINUTES CHECK THE PRESSIOR AGAIN IF YOU LOOSE PRESSIOR AND IS NOT LICKING OUTSIDE THEN IS LICKING INSIDE HEAD GASKET PROBLEM
Jul 30, 2009 | 1998 Honda Civic
2004 caddy deville dhs suspension service warning comes on
One of the irbags must be licking. My (02) was doing the same thing and I replace the shocks and problem ws resolved. However, my car looked a little low before the shocks were replace. These shocks are very easy to change and new ones cost me $240
Aug 14, 2008 | 2002 Cadillac Deville
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
