Question about LG 42PX5D 42 in. Plasma HDTV
Red screens cause flickering
When using virgin cable box, red colours (eg BBC background) seem to be too bright and cause the picture to flicker. All other colour screens are fine. Normal tv is fine. Could it be the virgin box signal or is it the TV?
  • stevedathome Apr 26, 2008
    Thanks for that. I am using scart cables at present (good quality ones), as this is all the box has (it is a samsung virgin v box and has no composite/hdmi sockets). Also, what do you mean by cable ch 3 please. I have scart to composite, would this be better?
  • Anonymous Mar 14, 2014
    the screen now flickers and the light source seems to be coming from the top LH side and picture is getting darker
    Genius:
  • 1,554 Answers
If normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Posted on Apr 26, 2008
  • Karl Whisenand
    Karl Whisenand Apr 26, 2008
    some boxes output to channel 3/4 on the rf .
    from the looks of the scart connector there are several versions of standards within it,
    there is not much you can do unless your an engineer and willing to modify the cable to drop the signal.
    that leaves you with using composite signal or switching out the box though it might be the tv at fault in dealing with the signal through that connector.
The screen is flickering
Call Samsung as on some of their models it is a known issue= on those a jumper needs to be removed from the power supply board, seems the wrong board was installed and is causing flashing on scene changes where brightness goes up and down.
May 27, 2012 | Televison & Video
Can see image but the screen is all red
Generally Tv screens use three different colours to make the picture, and if one or two of these colours don't show you will see the picture but in specially one colour (like looking through a red filter in your case).
If you are using an input into the TV (DVR or Games console etc) then I would firstly move the cable around in the back of the TV and the console to see if anything changes or flickers in and out of being correct. If this does happen I would recommend buying a new cable to fulfil the purpose.
If this does not happen and you are still seeing red then there may be an issue with the connection inside the back of your TV, this shouldn't be a very expensive issue to fix as you are still getting a picture but I would recommend getting a specialist to check it out if you are not confident in fixing this manually.
Thirdly and most unlikely is the settings inside the TV have changed, some TV's like yours will allow you to change colour settings on the screen. I would go into the menu and find the section that allows you to change the colours and have a check to see if any of the settings seem off.
Dec 14, 2011 | Sony KP-57WS500 57" Rear Projection...
Tv connected via scart cables through dvd and virgin media box. Picture sometimes goes yellow the flickers then back to clear.Other times it can go red. Plays dvd's okay though. Is this a connection...
This will be a problem with either the Scart leads (9 times out of 10) or the virgin media box. Not a problem with the signal coming from Virgin Media. Try checking the scart leads are not loose, or looped through the wrong way.
Hope this helps
TV_Doctor
Jan 03, 2011 | Sharp LC-32P50E 32 in. LCD Television
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Sony KP75HW40 unstable red. (not the usual problem)
I would suggest either the Focus block or the RED CRT drive board either one of those items could cause the symptom. A defective CRT could also, but a shorted CRT doesnt usually go back to being normal
Mar 16, 2009 | Sony KP-57HW40 57" Rear Projection...
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Picture Brightness Flickers
could be one or more of three things.
1.could be the crt itself.(sony had a bad bunch of crts for this model)
2.could be the vertical ic on crt board.
3.could be the focus block
in my experience solutions 2 and 3 are more common....
Oct 19, 2007 | Sony KP-51WS500 51" Rear Projection...
Lg 22ls4r hdtv screen flickers
Disconnect the TV from your sky box and watch TV with just aerial. If this cure the problem, then it is the sky box that may cause the problem. If not then your TV has a problem. Check the colour setting and make sure it is not in saturated mode. Otherwise take it back to the shop.
Jan 08, 2018 | LG Televison & Video
Picture Would Come In and Out, Now Not at All
It seems as though from your description it is just the brightness changing. The Cathode Ray Tube has three electron guns at the back end. These are for green, blue, and red. Each gun has a cathode and a grid. Nearly all control the brightness by having the grids tied to a variable voltage. And nearly all control the colour and luminance by an amplifier connected to each cathode. As you do not say the colours change the the amlifiers are OK. I would suggest the voltage to the grids ( or cathodes in some), is unstable due to a bad connection or a dry joint, or a faulty resistor in that part of the circuit. Very old sets without remote control used a potentiometer to vary the brightness. A voltmeter is all that is needed. When the picture goes off try holding the increase brightness for some time, to see if it reappears.
Oct 28, 2006 | Panasonic CT-36D32 36" TV
LG 42PX5D 42 in. Plasma HDTV Logo
160 people viewed this question
Computer Repairing
Computer Repairing
