No sound coming from speaker and when i open itunes its say it has detected a problem with my audio configuration and i try every thing and still no sound
  • maybehun Apr 26, 2008
    fixya thank you very much sound is back again i know were to go in further if i have a problem you have save me not quite sure how much but im sure its a lot of money
  • 758 Answers
Drivers are frequently updated to eliminate bugs or incorporate other changes. To download and install a new or updated driver, follow these steps:
1.Connect to the Internet.
2.Right-click My Computer.
3.Click Properties.
4.Click the Device Manager tab.
5.Click a listed device and a new window will open.
6.Click Drivers to see what drivers are installed on your computer.
7.Click Update and Windows will see if you have the latest driver. If not, you can update to the newest version if you wish.
You can also find updated versions of drivers by visiting hardware manufacturers' websites.
Did you run a virus scan? Which virus was on the computer?
Hope this helps
Computerrep
Posted on Apr 23, 2008
  • 38 Answers
Http://www.softwarepatch.com/utilities/ac97.html
Go here and download this program. It will take about an hour to load. I hope this helped you! = ]
-Robert Rivera
I have HP-Pavilion- DV2000 Laptop I have a sound problem because sound not coming out from built-in speakers, headphones or external USB speakers. Drivers in device manager seems to be OK Sound play cursor...
sounds like it can be the hardware. try to uninstall and reinstall the latest audio driver then configure your speaker settings and volume settings. if this does not work, you may need to get the audio card or motherboard replaced.
May 15, 2011 | HP Pavilion ze2000 Notebook
My speakers are not working. When I open itunes it says. iTunes has detected a problem with your audio configuration audio/video playback may not operate properly. I recently used some software 'Magix...
http://support.creative.com/
This is Creative's support link. The speakers you have are Dell. Do you have a sound card installed? If you have a speaker icon in your taskbar, lower right of screen, does it have a red X? Right click on it then, click on playback devices. A window should open with your device. Does anything show up and if it does does it show it "working"? Right click on it and a window should open and you should see "enable" or "disable", if it shows enable, click on that and exit. If you are still ahving problems with this let me know at "add a comment"
Dave
Mar 21, 2011 | Dell 5650 Computer Speakers
No sound at all..
I found several things to check about this issue.
First of all, make sure Windows Audio and Windows Management Instrumentation Services are running. Steps:
  1. Go to start -> run. If your keyboard has a ‘windows key’, which looks like the windows icon and is often located next to ctrl/alt, you can get away with pressing (and holding) this key, and tapping the ‘r’ key. I use this shortcut almost every day. On that note, windows-key+e I use even more- try it.
  2. type ’services.msc’, without the single quotes. This opens a list of the various services running on your computer.
  3. Make sure iTunes is closed.
  4. Locate “Windows Audio,” and see if it’s running. If it is, the status will show ‘Started’.
  5. No? Well guess what, iTunes needs this to be running in order to communicate with your audio device. Start it. There’s a link to start it along the leftmost column. Once it’s started, find a blank area within the services window, right click and hit refresh. Or just tap F5. Has the service died? If not, skip to step 7.
  6. The service died, didn’t it? Look for a ‘Windows Management Instrumentation’ service. This needs to be running for Windows Audio to be running, even though it’s not listed in the dependancies. Fire it up, then fire up Windows Audio.
  7. Fire up iTunes, and enjoy.
Secondly, you can open Control Panel and uninstall and then reinstall QuickTime. You can download QuickTime at this URL: http://www.apple.com/quicktime/download/
Third, you can try to reinstall iTune and allow any settings about playback and audio configuration with iTune during that.
Hope those helps.
Jul 09, 2010 | HP Compaq WF1907 Monitor
Itunes is detecting a problem with my audio configuration... my computer (laptop) wont play any sound at all. What should I do?
If you have audio managing software like Realtek, you can usually reset some options, and likewise, you can make adjustments from the audio and sounds menu in control panel. Most of the changes you can make are harmless and can be readily undone. iTunes could also just be acting stupid, like when it would screw up whenever I loaded AIM. You might want to see if there are some options that iTunes is set up with, which are causing the problem. When it gives you the message, saying it's detected a problem, see if you can read what it means by a problem. If you continue to have problems with iTunes, try using Winamp, it's a free download, and takes up little memory, and no spyware. Between those options, that should help resolve your problem.
Oct 23, 2009 | Gateway MX6920 Notebook
No sound except from warning sounds.
go to control panel again and click the "device manager" and seek for sound, video and game controler (speaker icon) -->click "+" whill show u is the hardware work properly or not, if not work properly will signity with "?" --> right click and click update driver
(if u have cd sound card driver do it while cd software inserted)
or reinstalling your sound card device software
open control panel-->double click add new hardware icon and follow instruction if ask are conected with the hardware click yes then next.. that way wil show u waht sound card type of yours -->
note : the "?" icon is the hardware need to a driver and not yet be installed..
i hope this will solve ur problem
Sep 18, 2009 | Audio Players & Recorders
We have no sound coming from our PC. There are
To check, click windows start button, point to computer, click manage, then look for device manager. If you see an exclamation or "x" mark on your audio device this means that your audio driver is not properly installed.
If audio no error marked sign and says that your audio driver is ok, uninstall it then re-install the audio driver.
Jun 04, 2009 | HP (153147-001) Sound Card
Audio configuration problem
I would suggest u to the restore your computer because somebody or you might uninstall the sound card software by mistake. Go on start then all programs then accesories then system tools and then restore
Mar 17, 2009 | Microsoft Windows XP Professional
I tunes has detected a problem with audio configuration audio/video playback
Go to Start> Run
Type in 'Services.msc' without the quotes.
Find Windows Audio in the list. Most likely it has not 'started', as stated beside each of the items in the list. Click on it, then click 'start'. Re open your itunes and it should be working.
Oct 17, 2008 | HP Compaq WF1907 Monitor
No audio when i try to play tunes in itunes
FIRST try the simple solutions. Check if your speaker wires are plugged into the proper ports.
If you are unsure, it won't hurt to try different configurations.
(If you hear sound from other devises such as plating a CD of the "Microsoft Sound" when starting up or shutting down, then the speakers are wired correctly.)
If this is OK then try...
Go to your "Device Manager" (Right click on  'My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Sound video and game controllers"). If there is some kind of a "Warning" icon superimposed on the 'speaker' icon there is your problem!
If no "Warning" icons then try...
One at a time...
Double click on each of the devises that have 'Audio' in the listings.
Click the "Properties" tab, look for any "Warning" icons
Uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Oct 23, 2007 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
David Payne
David Payne
