Question about Tascam DP01 All-In-One Recording Package Microphone
Tascam Portastudio DP-1FX/CD When I turn it on I get this message. Err: 12 Please PWR OFF
  • 189 Answers
This is basically an error message which indicates that the Tascam timed out while waiting for the drive to spin up. Usually an issue with the drive motor not getting the correct amount of power.
Primary suspect is usually the power adapter.
Posted on Apr 23, 2008
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
Did you find a fix to this problem? My dp-03 is giving the same error message and ALL my searching has led me to your posts.
Seems you haven't had a response. An authorized TASCAM repair center says it would be cheaper to buy a new one than have it repaired, but that seems NON-sensical to me.
How can An operating system error fix cost more than all the hardware in the unit?
TASCAM is about to lose MANY points with me, a PortaStudio user since the mid 1980's.
I purchased this unit as a close out, as is, and it has NEVER functioned since purchase.
Carol, please, PLEASE, tell me you found a fix.
Jeph O.
Apr 17, 2014 | Tascam DP03 Portastudio Multitrack...
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
Hello : I have a Tascam portastudio_dp_1fx. Anyone knows how to reset this message: Err: 12 Please PWR OFF
This error will only dis appear when you replace the ac power adapter that comes with it.
Or you better check if the output voltage and the amperes are not dropping.
Your power adapter should out with 12 volts and 2.5 amps. Less of this value means its dropping and its not stable..
You can use a multitester to check if the output voltage and amperes did not meet the requirements.
Hope it helps!
Dec 31, 2010 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02
I had the same message on my DP02 error 12 please power down. I went to an electronics store and asked a computer technician and he said it probably isn't getting proper power to start up .We looked at the manual specifications for power and found it needed a power adaptor which has an output of 12 volts and 2.5 amps which is 2500ma. Once I put that adaptor on it everything powered up and it works great.Look for an adaptor that says output 12v 2500ma and it should work fine.
Nov 15, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD Problem
nslo, tell him to try replacing the power supply first, power supplys burn up ALL the time, as long as the plug fits and it has a rating of equal or greater amperage, same voltage, equal to or greater watts then it will work. Those variable voltage multi plug ones they sell at k-mart work but I've never had one that lasted long.
Jul 09, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
413 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
