Question about LG LFC25760 French Door Refrigerator
Whirlpool refridgerator issue
We have a whirlpool refridgerator with the freezer on top with an ice maker in the freezer. The Icemaker is working fine.. but what is happening is the drain at the back of the freezer keeps freezing up and then the condensation backs up and instead of draining down the drain hole at the back of the freezer, it dripps into the fridge all over everything on the top shelf of the fridge. We've a taken out the bottom tray in the freezer and taken everything out to keep an eye on it,, but if I don't poke my finger into the hold every couple of days and removing the frost,, it will freeze over... Any idea? I've checked the temperature controls and I've set them to the regular setting... It's driving me nuts..
  • Anonymous Aug 13, 2008
    I have a 10 year old Whirlpool Refridgerator and it is pooling water all thru the fridge and especially under the vegetable bins where it freezes. I have not solved the problem
  • 76 Answers
Clear ice,clear drain, all the way to the drip pan, and tilt unit slightly to the rear
Posted on Jan 03, 2009
Whirlpool refridgerator with top freezer. Water leaks and pools at bottom of refridgerator under crisper. How do I fix the leak?
Here is a Utube video that will do the trick. Might not be your model, but same gig.
https://www.youtube.com/watch?v=VHD556AQ894
Dec 22, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Refridgerator Model ET18GKXGWO 1 Water collects inside Main Compartment what can I do?
Remove bottom and rear panel icemaker if so equipped there is a drain hole on the right-hand side next to the Styrofoam vents for the airflow that was blocked with ice
Feb 09, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Whirlpool model # ET1CHEXVB00 refridgerator. I just (few minutes ago) replaced the ice maker valve because water was no longer getting to the icemaker. Very shortly after I plugged the...
Sounds like the fill tube at the ice maker is either out of alignment or has a crack in it.
The water supply line from the water inlet valve enters the rear of the freezer and releases the water into a large diameter fill tube. The fill tubes hangs above the fill cup which funnels the water into the ice mold. If the fill tube and fill cup are improperly aligned, water may spill out instead of going into the mold.
Nov 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My top freezer is not cooling, but the refridgerator section is cooling. Refridgerator makes a clicking noise. What could be causing this? I have a Whirlpool 21.0 cu.ft with icemaker
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 20, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I noticed the freezer was not working as well as usual. The back wall of the freezer, by the ice maker (not hooked up) is very hot. What's going on?
The heater on the icemaker is staying on. Be very careful not to touch the bottom of the icemaker and remove it from freezer asap. Do not touch the bottom of the icemaker mold because thios will severly burn you. Take the icemaker out or the freezer wall will start melting.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water keeps gathering on top shelves of the refrigerator
for what you said what i think is the icemaker not shutoff the water valve or the the valve not working call service
Mar 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
LG LFC25760 French Door Refrigerator Logo
173 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
