GPX KL858S undercounter 8.1 inch color tv has gray screen and no picture. Sound is fine.
I talked with GPX Customer Service and they offered an upgrade for a similar unit which would be hi-def and digital capable for a nominal amount, I am hoping that this problem will not repeat itself in the next tv.
Posted on Apr 24, 2008
Why cant i watch tv?
CHECK T; CONE 3D OR THE SMPS, LVDS CABLE
Oct 17, 2015 | LG 42LD550 42-Inch 1080p 120 Hz LCD Hdtv...
We dont have a manual and we dont know how to change the channel or set the time
To set the clock on the unit, have the TV connected to power but not on. Then press and hold Mem/Clck Adj on the TV (it's the third button from the right in the top row of controls). Use the adjacent Tune/Clk (up/down arrows) to set the clock for 12 or 24 hour time. Then press Mem/Clk Adj again to adjust the hour with the up/down arrows. Press Mem/Clk Adj again and set the minutes. Press Mem/Clk Adj to save the time. The original remote also has these buttons. Mem/Clk Adj is also labeled Set and is the furthest right button on the second to bottom row of the remote. The Tune/Clk buttons are the DN and UP buttons on the left of this row.
Use the Tune/Clk arrows to change the radio channels after pressing the radio button (second from the right on the bottom row). When you press the TV button (first on the right of the bottom row) to watch TV, then you need to use the Channel up/down arrows at the top and bottom of the ring control on the far right of the TV or the Channel + and Channel - buttons on the remote. On the remote, the Channel + button is below the timer button which is below 9 in the keypad section. Enter is below the Channel + button and Channel - is below Enter. Make sure that the TV is in the correct mode for your signal (ATSC for OTA and NTSC for analog cable) by pressing the TV mode button. If you are using a set top box, you will need to change the channels at the box.
Press the TV Menu button and then go down the list to Time to set the time zone for the TV. Press Enter to save the setting. Use the TV Scan button to get a list of available channels before trying to change channels.
The manual for the GPX KL868S is available from GPX at the product page: http://www.gpx.com/store/p/287-KL858S.aspx . The direct link to the English version of the manual is: http://www.gpx.com/owners_manuals/KL858S-IB.pdf .
I hope this helps.
Aug 22, 2011 | GPX KL858S 8.1 in. Under Cabinet TV
My remote is lost, i have a universal, but i need codes!
you should have the manual for the universal remote. go to the universal remote website for a listing of codes and just look under gpx. all gpx codes will work with just gpx.
Feb 19, 2010 | GPX KL858S 8.1 in. Under Cabinet TV
Screen is dark
most likely a blown Backlight module, may need servicing if you can't take it apart and change the part, but I bet that's your problem. If so and this helps solve your problem, please give a fixya rating, thanks in advanced.
Gomez
May 16, 2009 | GPX KL858S 8.1 in. Under Cabinet TV
Projection tv has 2 pictures split with 8 inches of black
IN THE MENU GO TO COLOR CONVERSION OPTIONS AND TRY THAT ,,ALSO TRY NEW CONNECTERS
Apr 24, 2009 | Panasonic PT-52LCX65 44" HDTV
My gpx under the cabinet tv comes on, but after a few minutes the sound gets static in it, then I lose the picture, but the sound comes back perfect.
Double check the cabling, loose cable will case such issues, also try a different cable, if neither works, most likely you will need to exchange it.
Apr 02, 2009 | GPX KL858S 8.1 in. Under Cabinet TV
Gpx Under Cabinet TV
Have you tried to fine tune the channels? Other wise you need to set channels for cable and not air.
Jan 27, 2009 | GPX KL858S 8.1 in. Under Cabinet TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
