Question about Frigidaire GLTF1670A Front Load Washer
Replacing the detergent, bleach, softener water dispensing valve.
Re: Frigidaire GLTF1670A
Since my washer will no longer dispense the fabric softener, I believe the dispenser valve solenoid to the fabric softener cup is gone and the whole dispenser valve (pn# 131974700) needs replaced. I believe I am capable of doing the replacement, but I am looking for any guidance documents (service/repair manual) or shared information on the proper way to accomplish this without spending days with the thing apart as I try to figure it out. By the parts manual it looks like it should be readily accessible, but I am sure I have to unstack the dryer; if so, now that the top is off will I have access to the dispenser valve.
Given all the problems that are potential with these washers is there any secret to obtaining a service/repair manual for us DIYers?
  • HAW Branch Nov 02, 2008
    Same problem; also bleach won't dispense.
  • gar-pie Jan 27, 2009
    i AM HAVING THE SAME PROBLEM WHAT CAN I DO TO FIX IT?
    Problem Solver:
  • 6 Answers
I am looking for a repair book also, found a book was made called Frigidaire Gallery service manual, part number 659075, though I don't know if still available.  I was going to look on e-bay and alibris.com also -
Dennis
Posted on May 19, 2008
Bleach dispenser
Hello friend, I appreciate your post!
I understand your having an issue with the bleach dispenser of your Frigidaire front load washer. I would like to ask a couple of additional questions to better assist you. Is it not dispensing bleach? If you add fabric softener does it do the same thing? Finally, what is your model number so I may be able to proceed further? Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame. Thank you for the post and I look forward to assisting you. -Matt
Jul 22, 2014 | Frigidaire GLTF1670A Front Load Washer
Soap doesn't always dispense on any cycle. oap drw
Hello Bruce - The drawer requires two valves to open to dispenser: the bleach valve and the wash valve. If one fails, it will not fill the softener compartment. If there isn't any cold water supplied to the unit, it will not rinse the softener or the detergent. Possibly the washer may have a faulty water valve or an incorrect water supply to the unit. Also, if the softener dispenser cap is not installed properly, that can cause it to not rinse out as well. Because it could be a number of any one of several underlying causes, I personally recommend contacting a professional to properly diagnose and repair the unit.
May 29, 2013 | Frigidaire GLTF1670A Front Load Washer
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Water won't drain out from the spots where fabric softener goes
It typically has some residual water after a load. All you need to do is to remove the detergent dispenser and dump the water out. To remove the detergent dispenser, pull it out as far it will go, then look into the detergent slot. There should be a horizontal plastic tab in the back of the detergent slot. Press the left side of the plastic tab and pull the dispenser out of the machine. Then you can dump the water from the bleach and fabric softener slots. Just slide it back into the machine and your good to go. Hope this helps.
Jul 12, 2010 | Frigidaire Washing Machines
Fridgidaire front load will not empty fabric
Hello, W/D here.
There are a couple of reasons why the fabric softener will not dispense. If everything else dispenses properly (detergent and bleach), then I would suspect a bit of plugging. If the softener remains in the dispenser, the water valve above the tray may be sticking. You'll have to get the top up to check it. If there is water in the tray, or some water/softener, then you'll need to look at the overflow cap. Here's how that works: Your dispensing trays for bleach and softener have a raised tube built into them, and each is covered with a loose fitting cap. When water is let into the tray, the level rises under the cap until it overflows, creating a syphon. The softener is literally pulled from the tray, and chased by the water. When the water stops, the tray level continues to drop, until air gets into the cap, breaking the syphon. The cap can be removed and cleaned. Sometimes the tray has to be removed first. Theres a catch towards the rear of the tray.
Best regards, W/D
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load washer
HI. your model has a dispenser solenoid for the fabric softener dispenser on this unit. If the solenoids are out or malfunctioning, it will render the dispenser useless. i recommend checking the solenoids on the fabric softener dispenser for continuity. The resistance should be 1100+- 7%. replacing this blown solenoid will fix this issue. Remember. the dispenser valve will not function without a working solenoid.
please rate and god bless.
Mar 22, 2009 | Frigidaire GLTF1670A Front Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
286 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
