Question about HP Photosmart 635 Digital Camera
Download problem How do I clean the contacts? Where are they located?
  • 121 Answers
They ar located in the slot where the memory goes. I have used electronic contact cleaner with a thin "make-up" swab.
Posted on Apr 22, 2008
I need a new remote control for a tt 1620 recorder player
did you check the battery compartment for damage, dislocation or any visual oxidation of the contacts?
I've had the problem myself with oxidated contacts. After cleaning and adjusting the contacts, the remote worked fine again ;)
To check if the contacts are located good, just test if your batteries make good contact and are sitting tight between the contacts.
To clean the contacts, if necesarry, take a swap, dipped in cleaning alcohol or nail polish remover and clean the contact surface. Acetone works fine as well, just don't use any other cleaning fluids, because they may make the problem worse.
If the the contacts are seriously oxidated, you can scratch the worst off, with toothpick or a match. Metal objects may scratcj to hard.
Good luck :)
Andre
Nov 05, 2012 | Video Game Consoles & Games
Have background but no screen on my MX6000 Universal remote. Recently bought a new battery
you must reset the code again. try to download and put again.
read the owner instr. download from www.fitness.manualsonline.com
and download the code www.remotecodelist.com .
Clean the contacts batteries very well, with contacts cleaner.
2) retight the springs contacts with pliers for better contacts.
God bless you
Aug 30, 2012 | Universal Remote Control MX6000 Remote...
I have an kv-27exr20 and the remote cut the speakers off how do i get it back on
reset the code and try again download from www.remotecodelist.com
or remotes.com and proceed according with common sense. Try to clean the contacts batteries b) retight the spring contacts batteries with a pliers for better contacts c) resolder the wires contact batteries. d) try open the rem.control from clean to dust, dirty, oxide, bad contacts or open contacts, and repair. Remember they send signal infrared from Syscon transmittter vs Syscon Receiver, the signal can be very clean.
God bless you
Jul 31, 2012 | Sony RM-Y136 Remote Control
Volume is locked on 6 Only 0 to 9 Chanel are visible. remot is not working.
1) Retight the spring contacts with plyer very well, for great contacts.
2) Clean the contacts batteries with special spray contact for oxide.
3) Resolder the wires contacts batteries.
4) Reset the codes download for free www.fitness.manualsonline.com or www.remotecodelist.com
5) Otherwise you must open the remote for clean the keypads, with special spray contacts. or you must go to the repair shop.
God bless you
May 14, 2012 | Televison & Video
When i download music tone to phone it is in download history. how to i insert to a contact
Similar to all Android phones, open up your contact list and find the person who you wish to apply the ringtone to. After opening up their contact information, scroll down and find the button that says something along the lines of "Add Sound/Ringtone". Then hit save contact. Good luck!
Mar 20, 2011 | HTC Aria Cell Phone
Printer carriage stuck?
To fix cartridge errors, complete the following steps:
  1. Remove both cartridges (even if the message indicates only one cartridge). See your printer's manual or help files for specific information on removing and inserting cartridges. Most HP printers must be turned on to remove the cartridges. WARNING: Make sure to complete the procedure and reinstall the cartridges within 30 minutes. The ink in the cartridges can dry in the nozzles if the cartridge is outside of the printer for too long.
  2. Unplug the printer.
  3. Inspect the cartridges:
      If the cartridges are new, make sure the protective tape has been removed completely.Make sure the cartridges are not damaged. If the copper-colored electrical strip is torn or punctured, the cartridge must be replaced.Make sure the cartridges are compatible with the printer. See the manual for a list of compatible cartridges.
  4. Reinstall the cartridges. NOTE: HP cannot guarantee the quality or reliability of refilled or remanufactured cartridges.
      Make sure each cartridge is in the correct slot.Make sure the cartridge is snapped into place and the latch is closed.Close the front cover and plug the printer back in.
  5. If the steps above do not fix the problem, follow the procedure below to clean the cartridge and electrical contacts:
    1. Gather cleaning supplies:
        Clean distilled water. Use bottled or filtered water if distilled water is not available.Clean cotton swabs or any soft, lint-free material (coffee filters work well).
    2. Remove both cartridges.
    3. Unplug the printer.
    4. Lightly moisten the lint-free cleaning material with clean water.
    5. Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty. Figure 1: Cartridge nozzles and contactsc00059236.gif 1 - Nozzles 2 - Contacts Figure 2: Cartridge nozzles and contactsc00059237.gif 1 - Nozzles 2 - ContactsIf your cartridge doesn't look exactly like one of the illustrations above, locate the contacts by looking for an area with a number of small copper squares. The illustration below shows some representative cartridge contacts. Figure 3: Cartridge contactsc00059238.jpg
    6. Using a new swab, clean the cartridge contacts inside the printer (the print carriage). The illustrations below show contact locations for some representative carriages. If your carriage does not look like either of the pictures below, try to locate copper contacts inside of the printer that would touch the contacts on the cartridge when the cartridge is installed. Figure 4: Carriage contactsc00059239.gif Figure 5: Carriage contactsc00059240.gif
    7. Allow all the contacts to dry for at least five minutes, or dry them with a clean swab, then reinstall the cartridges.
    8. Close the front cover and plug the printer back in.
  6. If the steps above have not solved the problem, repeat them.
  7. If the error still occurs after repeating all the steps, replace the cartridges. If you have already replaced the cartridges once without solving the problem, contact HP. The printer might need to be serviced.
Jul 03, 2010 | HP DeskJet 5650 InkJet Printer
I cannot print right now the printer tells me that there is an error on the cartridge and refer to device documentattion troubleshoot
Read carefully this document from HP it will help you.
Solution
When the directions below ask you to remove the cartridges for a procedure, make sure to complete the procedure and reinstall the cartridges within 30 minutes. The ink in the cartridges can dry in the nozzles if the cartridge is outside of the printer for too long.
    • If the cartridges are new, make sure the protective tape has been removed completely.
    • Make sure the cartridges are not damaged. If the copper-colored electrical strip is torn or punctured, the cartridge must be replaced.
    • Make sure the cartridges are compatible with the printer. See the manual for a list of compatible cartridges.
    • Make sure each cartridge is in the correct slot.
    • Make sure the cartridge is snapped into place and the latch is closed.
    • Close the front cover and plug the printer back in.
  5. If the steps above have not solved the problem, follow the procedure below to wipe the cartridge contacts.
    1. Remove both cartridges. See your printer's manual or help files for specific information on removing and inserting cartridges. Most HP printers must be turned on to remove the cartridges..
    3. Wipe the copper-colored electrical contacts with a clean, dry, lint-free cotton cloth. WARNING: Be careful not to touch the nozzle area. The illustrations below show nozzle and contact locations for some representative cartridges. Figure 1: Cartridge nozzles and contacts c00059236.gif 1 - Nozzles 2 - Contacts Figure 2: Cartridge nozzles and contacts c00059237.gif 1 - Nozzles 2 - Contacts If your cartridge doesn't look exactly like one of the illustrations above, locate the contacts by looking for an area with a number of small copper squares. The illustration below shows some representative cartridge contacts. Figure 3: Cartridge contacts c00059238.jpg
    4. Reinstall the cartridges, close the front cover, and plug the printer back in.
  6. If the steps above do not fix the problem, follow the procedure below to clean the electrical contacts more thoroughly:
      • Clean distilled water. Use bottled or filtered water if distilled water is not available.
      • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    6. Using a new swab, clean the electrical contacts inside the printer, in the carriage. The illustrations below show contact locations for some representative carriages. If your carriage does not look like either of the pictures below, try to locate copper contacts inside of the printer that would touch the contacts on the cartridge when the cartridge is installed. Figure 4: Carriage contacts c00059239.gif Figure 5: Carriage contacts c00059240.gif
  7. If the steps above have not solved the problem, repeat them.
  8. If the error still occurs after repeating all the steps, replace the cartridges. If you have already replaced the cartridges once without solving the problem, click the link below to contact HP. The printer may need to be serviced.
Sep 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Magenta red will not print red, prints, yellow, I have tried 3 new ink cartridges for the PixmaIP6000D. Problem haappened when my Dell computer drive burned and had to install new drive. Running Windows...
Try unistalling the printer drivers and reinstall the drivers...here's a link in case you cannot locate your driver disk...
http://www.download.com/BJ-Printer-Driver-Canon-Pixma-iP6000D/3000-2116_4-10556279.html
If it still doesn't work, try cleaning the contacts between the color cartridge and the printer... Otherwise, your printer needs repair or replacement.
Nov 29, 2008 | Cannon Office Equipment & Supplies
HP Photosmart 635 Digital Camera Logo
24 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
