Question about HP LaserJet 3050 All-In-One Printer
No paper pickup press
Hi
I had a paper jam. when I removed the paper it says No Paper pickup press enter. When i press nothing happens. I have done every thing i can think of puting paper back in remove and then putting back toner. swiching off and on but the message is still there any help will be appreciated
  • 1 more comment
  • Anonymous Apr 22, 2008
    I also, had a paper jam, cleared the jam. Had the same problem as ramishrai. When I try to print or if a fax is coming in it makes a clicking noise, but no paper is not picked up. And now if I try to print the message is "this document failed to print".
    Exactly the same as ramishrai's problem. No paper pickup. When I try to print or if a fax is coming in you hear it clicking. Also, now if I try to print it says "This Document Failed To Print".
  • Anonymous Jun 04, 2008
    No paper pickup Press check
    If i press the enter button it beeps but the flashing yellow exclamiation mark does not go out.
    I have not cleared any jams or pulled paper out the incorrect way.
    From this blog it seems lots of people are experiencing the same thing. Whats up!!
A solution was found to this at http://www.devincollier.com/2009/02/14/hp-laserjet-3050-no-paper-pickup-solution/
there is a spring that has become unsprung.
Article has pictures
Posted on Jun 18, 2009
  • 62 Answers
It could be when removing the stuck page, it was removed the opposite direction of the paper flow and could have dislodge a component, my suggestion is to take in to acredited printer service centre too get checked out
Posted on Apr 25, 2008
Hello, I have a Dell 3130cn printer. IT is currently displaying the following message: Paper Jam 071-100 / Open Tray 1 and remove paper / Open and close the Front panel. I have done all of these things. I...
This error can also be caused by other problems, two of which are as follows.
1) The paper tray has a flap which opens when the MPF (Multi Purpose Feeder) is lowered. If this flap has been pushed out of one of its pivot points due to 'rough' handling of the paper tray, it can cause paper jams, and it can sometime cause the printer to 'think' it has a jam.
Just re-locate the flap properly, and make sure that it does open when you pull the MPF down.
I've seen this happen on a fe of these printers - keep your thumb OFF the flap of the paper tray when you open and close it to reload it with paper.
2) Paper quality can be a cause - seen this happen on this printer when a different paper was used - more likely with a printer that has done a lot of work and the pickup/transport rollers are starting to wear.
Replacement pickup and transport rollers are available quite cheaply on THAT well known internet auction site (and probably elsewhere to)
Apr 19, 2010 | Dell 3130cn Color Laser Printer
Printer mispick
Hi ,
The print engine has failed to pick up a piece of media.There is a paper jam in the printer's paper path. Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
HP Deskjet F2290, unable to print after paper jam
just On it twice and then off,, check you have removed paper jam and installed drivers.. aall
Sep 28, 2009 | Office Equipment & Supplies
No paper pickup
Hi damodarbk:
it sounds like you need to replace the paper feed rollers.
pdouglasss
Jan 03, 2009 | HP LaserJet 3050 All-In-One Printer
Paper Jam
Most likely a bad or obstructed sensor. Use compressed air to blow around the top and back of the printer removing heavy paper dust and look under the pickup rollers for small pieces of ripped paper. If the sensor is bad, contact service and support.
Jul 29, 2008 | Canon PIXMA MP460 All-In-One InkJet...
HP Laserjet 3050 No paper pickup
My printer now spits out the paper all over the place and jams up all the time. Did not happen when I first got my 3050 a few months ago.
Jun 06, 2008 | HP LaserJet 3050 All-In-One Printer
Paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
Printer says it is jammed
unplug printer from wall for 12 secs and plug back in
Jan 15, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper Output Slot
Hi John,
Some small piece of paper or something stuck in the printer path, remove the paper feed tray and clean it completely , open the printer cover and clean any particles, try cleaning the printer head path also... if nothing is visible try using a torch light and then clean it from inside.... once done with all cleaning switch on the printer, things should be fine now... if not
Please get in touch with canon service center, if the printer is still in warranty, or try to contact local serive center....
Hope this answers your post, please let me know by providing your valuable feedback....
Thanks,
Robosoft.
Dec 23, 2007 | Canon Pixma MP500 All-In-One InkJet...
Paper jam
try to remove all ink cart. and re install again...
Aug 27, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet 3050 All-In-One Printer Logo
1,936 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
