The 4:3 is an aspect ratio the ratio of horizontal to vertical size and the non-HDTV standard; the latter is 16:9.
The PAL and NTSC abbreviations refer to the picture and synchronization standards whereby NTSC is the American standard and the PALs are European.
The setting "sp-raw" refers to an unprocessed video format that requires further processing before it can be viewed. If the disk you have was made for the American market, you should be set to NTSC and the aspect ratio to whatever the disk is specified, most recent disks will be made to conform to HD specifications, but may also be viewed in "letterbox" form which is a shrunken 16:9 box with pronounced edges around it.
If you are not using the car power adapter that came with your PDV-768 for the 2nd screen, you are likely running into the possibility of "reversed polarity" with the power adapter you are attempting to use. This can & often will cause a problem with your unit.
