Question about Toshiba 36AX60 36" TV
Toshiba TV 36AX60 power light blinks and no picture
Hi you mentioned that this problem is the regulator IC. If I was to purchase this can I replace it myself? If I order it do I describe it as such ( regulator IC) ?
Thanks for your help.
My email is fireman-jim@wi.rr.com
I bought this model tv back in Feb. 2001. It had run perfectly (average 10 hrs. daily) up until August 2009; the red power light began flashing intermittently. A few weeks later, my picture began to distort, then go to normal, then distort again. The problems got worse and worse with the picture and I called the place where I bought it. The person that came out and looked at the tv said I should just junk it and buy a new one. I called the store to complain and another person came out, took the whole tv apart, and knew exactly what the problem was. He said the tube was fine, but there were at least 20+ solder joints that were bad as a result of heat and normal usage. The joints were repaired right in my living room, the tv was reassembled, and the tv is running perfect for now. I will keep everyone posted as to how things go in the future. Total cost for them coming out and doing the repair was $250. Hope this helps someone.
Posted on Oct 14, 2009
    Scholar:
  • 186 Answers
I don't believe it this is a DIY project. I think this takes an experienced repairman for this project.
Posted on Apr 24, 2008
We have no picture or sound. The sttandby light blinks 7 times then a pause and blinks 7 more times. it keeps repeating this. This is a Sony Trintron TV
Hello
Seven blinkings of stanbylight in Sony sets denotes a High-Voltage shutown problem. Not means the high line voltage, but the fault inside the tv itself. You haven't mentioned about the model number of your TV, yet I'm going to describe you considering this as a standard Sony problem.
The fault is mainly due to the internal power supply regulator section in your TV. It is now supplying voltage more than normal that it is meant for, as a result the EHT [Extra High Tension] voltage to the final anode of the picture tube goes higher than normal, and the microcomputer Ic inside your Tv detects this voltage difference and giving you the fault symptom in 7 continous blinks. That Ic is so programmed such, it will blink with certain times according to the fault comes inside, and helps us to locate the faulty section without opening the TV.
As I said above the fault in your TV lies on the power regulation section. You just open your TV and locate that section, which can be easly located as the main power just goes to that portion, and there will be a regulator normally Sony uses STR***** type IC regulators, which will be screwed onto a metal heatsink to radiate heat from it while it works. These will heat up to 80 degree C, while working, and the heat generated by this ic can cause loose solderings on its legs. You resolder its leg solderings, and suspected solderings around it, by applying a little more solder. In most cases this will resolve the problem. Ok.
Nov 13, 2010 | Sony Televison & Video
I was watching the TV when it suddenly turned off. The audio fom the cable channel was still running on the independent surround audio system and I could change channels on the cable box. The power light...
Your partial resonance power supply IC with IGBT switch is bad. You will have to have tech replace it for about $50.00. The reason why your audio system still runs is because it is not part of your tv.
Sep 04, 2010 | Toshiba Televison & Video
Toshiba tv - power on - black screen and power light blinking -
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Sep 27, 2009 | Toshiba 36AX60 36" TV
Toshiba 60HX70 distorted picture, blinking red light
You could have a Power Supply Regulator Problem. Many times these sets will not hold Horizontal sync when there is excessive High Voltage or a problem with the High Voltage Regulation. This is not a problem you want to deal with yourself. I would recommend a Toshiba Repair Facility to come out and diagnose it.
Hope this helps,
Skyassoc
Jul 22, 2009 | Toshiba 61HX70 61" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Tv power light flashes on and off, but no picture or sound
the problem is, the system control or "jungle" ic as the call it was malfunction need to replace.need more help....dnlsabangan@yahoo,com.
Feb 15, 2008 | Toshiba 36A61 36" TV
Toshiba 36AX60
Often the number of red flashes symbolize an error message of a specific component. Also try unplugging for an hour or two and try it again to see if problem disappears or changes.
Jan 09, 2008 | Toshiba 36AX60 36" TV
My tv has a black screen
I would bet on the regulator IC. :>)
Aug 17, 2006 | Toshiba 36AX60 36" TV
Power light is blinking TV does not turn on
Mosy likly the regulator Ic in the main power supply . Not a consumer replaceable item because of xray and safty issues Call in a shop to assit you in this matter. Good luck
Jun 14, 2006 | Toshiba TP55G90 55" Rear Projection...
Toshiba Rearprojector TV
you didnt say if the set was working?? if its not I would first try the power regulator IC in the power supply It will start with an STR#####.. This goes bad alot in these sets. Good luck
Apr 17, 2006 | Toshiba 40H80 40" Rear Projection...
Toshiba 36AX60 36" TV Logo
162 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
