Question about Refrigerators
Frigidaire refrigerator with ice maker leaks water
Water leaks out the bottom onto the kitchen floor and is ruining hardwood floors-it collects at the bottom of the freezer and makes a noise before it leaks everywhere
  • wina Apr 22, 2008
    no kidding how do i fix the problem
  • Anonymous Mar 13, 2014
    Water collects below the storage drawers. I think it is coming from the freezer. Once it pools, it leaks out the refrigerator door onto the kitchen floor.
  • 552 Answers
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
Posted on Apr 22, 2008
The fridge is leaking water and going onto the floor underneath the fridge how can l fix this problem
If equipped with Ice Maker and water dispenser we can assume that the water feed has developed a leak. To confirm protect the floor in-front of the machine pull the machine out from the wall and reach around behind and turn off the water feed. CAUTION the wheels from a full machine will scar the kitchen flooring. Mop up the water and dry out the floor.
If the water no longer returns than you can assume that the source of the water is with the ice maker or water dispenser.
If the water continues and the machine operates normally (freezer below 10 F and refrigerator < 40 F) then it is the defrost cycle. The good news the ice maker might be alright. The defrost cycle has a drain tube. About twice a day or less often the machine has an automated defrost that allows for the ice build up on the evaporator coils to melt and run through a tube to a tray under the machine. the water in the tray evaporates between cycles.
First check if there is any water collecting at the bottom inside the refrigerator portion of the machine. If so with the water turned off you can be certain that the defrost cycle water is not being contained with in the drain tube. It is common that the drain tube can either plug from lint etc or ice over, Included i will link a few videos describing the situation and depending on your model a course of action.
How to Unclog Refrigerator Drain Line
https://www.youtube.com/watch?v=4SEe5z9JrMU
Jan 10, 2016 | Refrigerators
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Leaking under left side. water lines ok. too close to ground to see where water is. hardwood kitchen floor is buckled. ice maker is putting out too much ice and falling out onto shelf. what do i need to...
It sounds like the water tray for the defrost mode is full, you need to check if the tray has moved or maybe the door rubber are not sealing and this will cause extra ice built-up, and will cause the leak.
Jun 02, 2011 | Refrigerators
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Dec 08, 2007 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Sep 26, 2007 | Frigidaire FRS26R4C Side by Side...
Refrigerators Logo
544 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
