Frigidaire top loading wash machine will not pump water out
    Genius:
  • 1,073 Answers
If the oump is running check the oump for foreign objects in the pump and a stopped up drain hose if you have washed any blankets or rugs lately
Posted on Apr 23, 2008
I have FAFW3574k- Fills w/ water. Starts to run cycle but then wont spin. Pump sounds like its running but water doesnt come out. Thanks Jeromy
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2011 | Frigidaire Washing Machines
Will not pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 10, 2011 | Frigidaire Washing Machines
It will not pump the water out
heatman101 ..
Oct 10, 2010 | Frigidaire Washing Machines
My washing machine will not drain th water out,at the final spin the water will not ring out
heatman101
Oct 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire washing machine top load. troubleshoot
There are levelers at the corners of the unit for levelng - tubs have springs attached to them for righting the tub while working (spinning, agitating) - also if the clothes are evenly distrbuted in tub it will wobble badly during operation.
Leaking is usually from the drain pump especially from the point whwere the hose is attached to the pump
Regards
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
