Question about HP PhotoSmart 7760 InkJet Printer
Printer is not turning on
I took the color cartridge out to shake it and failed to get the lid snapped doen tight. Hence it got stuck under the cover on the left side. I turn the printed off to work on the getting the cartridge loose. I got it loose and it would not turn back on. I have tried disconnecting and reconnecting the printer. I have tried holding the on button down a long time. No luck so far.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Generally all cartridges must be securely in place before printer will power up. Make sure that all (including the one that was not right) are now securely and properly in place. Then, I would sugget actually unplugging for at least 2 minutes, in order to ensure anything that could be "stuck" in memory clears. Then attempt to power it back up and it should work. (As an aside - did you replace the cartridge at issue with a new one, or just put it back in once it was fixed? If you don't power on with the above, replace that with a new one.) Thanks for rating FixYa!
Posted on Apr 24, 2008
  • Cheryl Whalen Apr 26, 2008
    tigrefire: If my response gave you the info you desired, could you please go in and rate FixYa? Thanks!!
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
Tip
How to replace the ink cartridges on a Dell All-In-One 948 Inkjet Printer 1....
1. Turn the printer on.
2. Lift the printer unit.
3. The ink cartridge carrier moves and will stops at the loading point unless the printer is busy.
4. Press down on the ink cartridge lever to raise each ink cartridge lid.
5. Remove the old ink cartridges from the printer.
6. If you are installing new ink cartridges, then remove the sticker and transparent tape from the back and bottom of each ink cartridge.
Note: If you are wanting to print photos you will want to install a photo cartridge along with the color cartridge. Also if you are switching between the photo and black cartridge but they still have ink in them be sure to store then in an air tight container so they do not dry out.
7. Insert the new ink cartridges. Making sure that the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
8. Snap each lid closed
on Apr 01, 2010 | Dell 948 All-In-One InkJet Printer
How do I slide the green toner tabs?
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover (it is the full length of the cartridge holder).
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Apr 20, 2011 | Brother HL-4040CN Laser Printer
DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
Follow the below instructions
  1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
  2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
  3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
  4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
  5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
  6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
  7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
I hope this clears up your problem.
Good Luck and Have a Nice Day!!
Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
How to replace ink cartridge
1 Make sure the All-In-One is on. 2 Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy. 3 Grasp the tabs on the cartridge lids, and then lift the lids. 4 Remove the old cartridges. Store them in an air-tight container or dispose of them. 5 If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges. 6 Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed. 7 Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to power source.
Dec 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
How do you change ink
To Change the ink Cartridge please follow the instructions as under:
  1. Turn on your computer and open the front cover of your printer.
  2. The Cartridges will automatically come in center.
  3. Pull up the holder lid and carefully remove the print cartridge on a 60 degree angle.
  4. Press the ink cartridges into the slots and listen for a clicking noise after the insertion
  5. Remove the tape from your new print cartridge and carefully put it in on a 60 degree angle, snap the lid back in place. close the printer.
  6. Open the printer software in your computer, click the tab maintenance and click install a new cartridge and click the number. Print an alignment page.That's it !
Thank you for using Fixya
Oct 08, 2009 | Lexmark X4550 Multifunction Wireless Color...
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
