Computers & Internet Logo
Posted on Jul 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer is very slow and I need not much time left standing
Anonymous
Level 3:
  • Master 808 Answers
  • Posted on Sep 03, 2010
Anonymous
Master
Level 3:
Answers
808
Questions
0
Helped
142874
Points
1763
Use some gud registry cleaner with other features like browser cleaner registry defragment and manage start up to boost up performance of ur pc like reginout reg-cleaner.
Anonymous
Level 3:
President:
  • Master 2,291 Answers
  • Posted on Aug 20, 2010
Anonymous
Master
Level 3:
President:
Answers
2291
Questions
0
Helped
424887
Points
4304
Turn off unnecessary programs from start up: A lot of computer users complain that their Windows 7 or Vista does notboot faster. I would recommend to such people to have a shorter startup items list.
Have low intensity graphics If you are not an ardent gaming user then you can afford to run computer faster with low intensity graphics.
Uninstall unused software and programs: It is very common that people install a number of computer programs andthen stop using them. These unused programs shall be removed toincrease the computer speed.
The above guidelines were reallyhelpful to speed up my computer. These are safe and do impact computerperformance in a positive way.
Frustrated of the dead slow speed of your computer? Do you wish to speed up computer in seconds? Please remember to clean Windows registry with Intel Software Partner, RegInOut BY After this scan you will feel how much faster is your computer running.
Nick Kail
Level 2:
Scholar:
  • Expert 94 Answers
  • Posted on Jul 23, 2010
Nick Kail
Expert
Level 2:
Scholar:
Answers
94
Questions
0
Helped
34592
Points
287
The reasons for a computer being slow could be either that you have a full hard drive low memory or possibly and more likely you have malware on it. first thing to do is run and anti malware program like Malware Bytes
Download the free version and allow it to update and run a scan. once this has been done your PC should run a lot faster.
If not check your hard drive free space if it is below 15% you need to delete some of your old files and programs to free up some more
Lights are not on but brakes need to be pumped to slow down. also, when turning left after slowing down , i hear a popping noise
Hi,... as for the popping sound,need more diagnostic input,like >>>what are you driving>>> given what you have on brakes ...1- check your master cyl. under the hood for fluid level , if ok, 2-with the vehicle in park & running,step on the brake about half way down rapidly about 10 times , done pumping the pedal up, stand on it and hold a great deal of pressure on it , does it slowly sink to the floor ??? if so,replace master cyl.if it holds , you have air in the system from a leaking wheel cyl./brake line/caliper ??? good luck !!!
Why is power steering fluid spewing out of the cap after replacing bad leaking power steering pump
You have Air in the Power steering System and it needs to be bleed out, And to do this if you Jack the two front wheels off the ground and Let them Hang free so there is No Load on the steering at all. please put some type of stands under the car, You will need more power steering fluid but before you add this you need to start your Car and turn the steering Wheel Slow from left to Right a few times, You will hear a wearing Notice come from the pump and you will see more fluid come out of the pump as well, that is the air trying to bleed its self out. The fluid coming out will be air rated lots of bubbles in it, Now that you have done this the Noise from the pump should start to go quite at this Point you can start to Add the New power steering fluid slow to the reservoir and keep turning the steering wheel from left to right slow (Never Fast but slow ) Have a lot of rags to clean the Mess. Hope this helps you. :)
Crunching and grinding
sounds like a strut mount
Quingo plus wont freewheel been left standing for some time
sounds like the cable might need to be oiled or tightened when they are left standing for some time they some times slacken and need tightening up and or oiled.
1helpful
Clunking noise when turning boxer van
One of the driving shafts cv bearing worn out ,Drive in the park turn left not noise turn right you have noise ,notes right turn noise is left cv and left turn is right vc join .2nd the most of the times the long-standing shaft damage the cv bearing first..
2helpful
2answers
Standing water in dishwasher
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
1helpful
Why does the engine shake when slowing down?
The engine will shake when slowing down, because releasing the accelerator drops the rpm of the engine immediately. The engine only "knows" it has slowed down and will shake the same way if standing still.
There are many reasons for the shaking. All are due to needing a tune up. Poor timing, plugs, wires, cap, rotor, etc.
If you need help fixing something, give me a call.
TomE
Left rear drum brake lockes up also when stepping
leaking brake fluid causing it lock up and grab ,slight leak anything more and it just will not work at all
Tight steering
Some power steering systems have a high effort function, a sensor controls output pressure(to the wheels) proportionate to input pressure (steering wheel) You need the Dealer for this one. Safety is a major concern, loss of control hazard is present
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
