Question about Samsung HCM5525W 55" Rear Projection Television
Red shadow line
My TV has a red shadow line on all letters numbers and people. I have tried the auto convergence and the manual but the little crosses will not move togeather they wont move at all. Help
    Problem Solver:
  • 6 Answers
I have the same samsung 55 inch rear projection TV. Replaced the convergence board two years ago, and it is out again.
This time I will just replace the STK392 IC's. I have read that it is best to upgrade to the higher capacity onces, say the 110, 150 or 180. Question: Is this a direct replacement, or do you also have to replace any resistors to provide them different voltages.
I have seen several different opinions.
Posted on Apr 26, 2008
  • 121 Answers
You need 2 convergence IC's this is an easy repair take the back off your tv and they are on the right hand side of the board mounted to the heat sinks check your ic's for the stk numbers it will either be STK392-010 OR STK392-040 you will need 2 of them I will post you a link where you can get replacement ic's as well as free online tech support and installation instructions with pictures for reasonable price
http://servicemanuals.vstore.ca/
Posted on Apr 23, 2008
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
Toshiba 50HX70 Convergence reset
press mute button once after press and keep pressing mute again and press de menu button on tv .when tou see S on screen press 7 you are in convergence adjusting mode
Aug 03, 2008 | Televison & Video
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
I have a Mitsubishi 65" HD-1080 big screen tv. Today when I turned it on it had a red shadow all over it and the red tube was off by about an inch. The TV has an automatic convergence function that I...
Convergence ICs need to be replaced. post the model number and I will list which ICs you need and where you can get replacements with free installation instructions.
Apr 26, 2008 | Televison & Video
Convergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 23, 2007 | Toshiba 50H72 50" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Another Convergence Problem?
dont move the pic tubes that will be a costly mistake the problem is still your ics replace them all you should have two check for bad solder connections
Nov 12, 2006 | Toshiba 50HX70 50" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
89 people viewed this question
Henry  Thomas
Henry Thomas
