Question about Canon PIXMA MP830 All-In-One InkJet Printer
Service error 5C10
My printer won't print. It just says turn off the printer then turn back on. See service error 5C10. Check your manual. The manual is lost and so am I!!
  • 54 Answers
Http://software.canon-europe.com/products/0010326.asp
uninstall the software and download the latest software from the above side and install it
Posted on Apr 29, 2008
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5c10
This error is a message indicating print head/ink failure on the printer.
I would try the following 2 things:
1. replace the ink cartridges/print heads. test to see if the problem is fixed.
2. If this does not solve the issue, you may need to either send it to the manufacturer for repairs (if under warranty), send it to a local repair person to service- or look for a new printer to buy (which may actually save you money).
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error message : service error 5c10 on a canon
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
or
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
Apr 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I keep getting error 5C10 and can not print anything. Have turned it off and on and still doesn't work.
Jan 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Printer won't print. Check printer error message
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
Dec 13, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error message 5C10, won't print. Need locations
I think there was a broken pieces of hardware in the print carriage.
According to the Canon Center this one cannot be fixed. If your printer is under warranty, send it to them.
Read also this online user's guide for your machine.
www.yboyandrei.com/MP830_Err5C10
Please rate me if i am helpful to you.
Oct 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
CANON iX500 error 5C10
5C10 error message. cancel the print job and turn printer off. for 5min by unplugging it from all source of power supply this will occasionally rectify the problem, hope this helps pls do let me know
Mar 31, 2009 | Canon Pixma iX5000 InkJet Plotter Printer
Service error 5C10
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
This will reset the printer and should resolve incorrect cartridge detection problems
Mar 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
561 people viewed this question
old marine
old marine
