Question about LG Televison & Video
Have a LG cd/dvd receiver DA3630 with open/close problems (two other family members have the same problem with the same system). Problem started short after buying the sytem but from once in a while it became a continious problem these days. The system was not extremely used (approx. once to two times per week).
fieldy14
  • 456 Answers
SOURCE: LG DVD recorder/VCR Combo problems
you need to replace the dvd loader(the whole setup, the draw/tray,laser sled assy ,etc) statewide sell
parts for lg.unless you know an authorised lg repair agent.too bad you dont know me, lol.
(ps,its not in the manual,cuz there is nothing you can really do about it without serviceing the unit)
Posted on Oct 10, 2008
SOURCE: dvd tray will not stay closed. opens and shuts randomly
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.9acead3.jpg
Posted on May 22, 2009
SOURCE: 2 lg dvd players in same room,can I change remote frequency
I have new Panasonic DVD & Combo units stacked on top of each other and had the same problem, until last resort I read the manual and and easily changed the frequency on the DVD unit and remote, you can have up to 3 Panasonic units with different frequencys close to each other.
Posted on Oct 22, 2009
SOURCE: LG RHT 398H. DVD tray not closing.
I've dismounted the unit and it seems that I have located the problem. The tray is connected to a wheel, so any displacement is translated into a rotation of this wheel. When the tray is near the close position, it releases a mechanism in order to position the lens. Summarising: if you have pushed the tray with your hand instead of pushing the button open/close, probably you have introduced a desynchonization. To solve this, when the tray is in close position, apply a small rotation to the wheel in order to compensate the desynchronization. There is not an exact position, but you need to try. A few degrees is enough. Regards
Posted on Mar 31, 2010
SOURCE: DVD TRAY KEEPS ON OPENING AND CLOSING CONTINOUSLY
Hi, I have exactly the same thing. Happened before but went away when I got bored trying to fix it. This time I phoned LG support and they said take it back to Comet (they have bought out their servicing). End of conversation. Polite but firm.
Appalling support via their websites, appalling products. Never again.
Posted on Apr 24, 2010
When i enter cd/dvd into lg dvd drive it does not show anything
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Aug 16, 2012 | LG GH22NS70 Super Multi 22X SATA DVD...
I just installed my new LG super Multi DVD REwriter and the light comes on but nothing else happens I put theinstall disc in and still nothin happens...
check the power leads that attach to your lg external dvd drive make sure they are securely seated and consistent power is getting to it also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Sep 01, 2011 | LG SecurDisc 20x External Double-Layer DVD...
My computer [Operating on windows 7] seems unable to detect any discs I put into my LG CD drive. I tried some basic trouble shooting, but I receive this error: 'The disc in drive [D:] is not detected,...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 27, 2011 | LG Computers & Internet
My lg dvd writer cannot recognize any discs. wat might be the problem?
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 07, 2011 | LG GSA-H55N DVD-RAM Burner
My lg dvd GSA-H55N writer stopped working.led is not fleshing,as well as theirs no logo on my computer. my first boot device was cd/dvd and second was hard disk but after this problem first boot device...
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
or if these fail to resolve the problem
hope this helps
don
Feb 20, 2011 | LG GSA-H55N DVD-RAM Burner
Not recognizing cd or dvd.No power problem
your drivers may have been corrupted or you might have a virus run your antivrus program
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 26, 2011 | LG GH22LP20 DVD±RW Burner
On my LG RH387H dvd hard drive the dvd tray won't open fully and now it has started to open on power up and when i try to close it it keeps opening even though there is no dvd inside
mechanical timing and allignment is the prtoblem of your dvd player...you need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand..make sure that the cd loader reaches the limit switch before it closes..
May 18, 2010 | Televison & Video
No sound in DVD mode
when i turn on sony receiver it will not play it just says protect on the screan
Dec 21, 2008 | Sony STR-DE445 Receiver
Door
Hi abdu
The problem is that at some stage you or someone else forced the cd open or closed, but not to worry, it's not broken. What happened is that the gear that pulls the tray in, mite have slipped a tooth or two. You'll have to open it up. Take the top cover off. It has four small screws holding it. When you take the cover off, the gear system should reveal itself. Now the gear that pulls the cd tray in and out must me ajusted. Before you open the dvd writer, make sure it is in it's utmost closed position. Very Important!. There should be a screw in the centre of this gear. Carefully unscrew completely. Now it depends on which direction the gear turns when it close the tray. Seeing that it doesn close completely, the gear turns anti clockwise to close. Lift the gear in a up sliding position and turn it one teeth clockwise, press the gear back, fasten the screw and test. If it still needs more adjustment, repeat the process with another teeth clockwise. Note if it worsen that it doesn't close, then you need to reverse the process and move the gear anticlockwise, but make sure to mark the teeth that it was originally on when you opened it.
Hope this helps
Cheers
Deon
Sep 10, 2008 | LG (GCE-8527B) CD-RW Burner
Closed Captioning
you would open it in the plasma disply as it has to be on to work in one mode
Sep 08, 2006 | Yamaha RX-V1300 6.1 Channels Receiver
Televison & Video Logo
108 people viewed this question
Computer Repairing
Computer Repairing
