Question about Whirlpool Refrigerators
I have a whirpoool conquest ref. and ice maker is not working it's not making ice cubes. looks like water is not entering to the ice cube part .ice cubes comparments are empty .howeevr water is entering to the ref, since i can get water from the front door of the ref.
    Genius:
  • 1,478 Answers
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Either from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Take care.
Posted on Jul 23, 2010
  • 1 more comment
  • luis789us Jul 23, 2010
    is the water tub inside the frezzer ?
    I opened the frezzer door , remove some platic walls and couldn't see any tube / or water hose in the back of the frezzer wall ,how ever on the top of the frezzer,rigth above the ice maker ,, i do see a litttle black hose end , but looks like this hose is coming from the internal walls on top of the frezzer .
    quwstion the electronic sensors inside the frezzer can controll any water valve to regulate the water getting in to the ice cube maker ?
  • Jimoh Adeleke Muyideen Jul 23, 2010
    An icemaker receives water through a small, 1/4-inch
    water supply line that runs from the refrigerator to a water pipe, where
    it is connected by a tap valve. The water supply line enters a valve in
    the refrigerator that is controlled by an electric solenoid that sends
    water through a fill tube into a mechanized icemaker assembly.
    Here are a few steps you can take to get your
    icemaker working (be sure the bail wire above the ice tray is in the
    down position):
    1) If the icemaker doesn’t make ice but you can
    see the arm swing into motion and you hear a buzz for about 10 seconds
    after it is finished, the water valve is asking for water that isn’t
    arriving. This means the valve and the solenoid are probably okay, but
    the water supply is not. Be sure the water supply line isn’t kinked
    behind or beneath the refrigerator (1/4-inch copper tubing is much
    better than plastic fill line).
    2) Check to see if something has caused ice to back
    up around the mechanism—this can cause the fill tube to freeze, blocking
    the mechanism. When ice cubes are small and seem to be getting smaller,
    it generally indicates a frozen fill tube.
    3) Check the water
    line that enters the back of the freezer for a blockage. Find the water
    shut-off valve behind the refrigerator or under the sink, turn it off,
    unscrew the copper line from the back of the refrigerator, put the
    copper line in a bucket, turn on the valve, and see if pressurized water
    pours out.
    4) Check the tap valve; a bad tap valve may cause the
    problem where the icemaker’s supply tube connects to the water pipe. If
    necessary, replace the inlet valve and the tap valve. For the tap
    valve, use the type that requires you to drill a 1/4-inch hole (as
    opposed to the “self-piercing” type). You can do this yourself.
    5)
    The water line attaches to a solenoid at the back of the refrigerator
    and then travels to the icemaker. The solenoid may be defective or may
    not be receiving power. You can try removing the sediment screen inside
    the solenoid and flushing it with water to clean it, and at the same
    time you can inspect any seals or diaphragms to ensure that they are
    sound. Unplug the refrigerator first. Unless you’re skilled at home
    repairs.
    Take care.
    ok , i will try tomorrow , too late rigth now, will advice you of the results .
    thanks , will be in touch
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker stopped making ice
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator icemaker does not dispense ice cubes
I don't think the ice maker liked the water being turned off. Usually there is an arm that will raise up to a catch position that will turn the ice maker off. I hate to say it, but ice makers are best to replace than repair. The internal parts are difficult to change, and with a new one you will have no problems. They are not too hard to change. Shop around for a good deal, I use e-bay.
Apr 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ice dispenser not working, but water is
There are three common problems with icemakers:
There's no ice
Small or too few ice cubes
Specks in the cubes
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Water dispenser working but ice maker not working
is water is in side ice maker if not check hose at the back if water in icemaker call for service
Mar 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker
That means that the solenoid that controls the ice maker is defective and must be replaced with a new one.
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Jul 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice cubes
enoty and wash out the ice bin with hot water and let air dry, before you reinstall the ice bin
Be sure to turn off the ice maker so it will not make ice while the ben is out of the ref
Apr 15, 2008 | Whirlpool ED5SHAXM Side by Side...
Adjusta ice cube maker not working
Have you checked if water is comming out the tubing before hookup? A valve may be close...
Dec 10, 2007 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
