Question about Canon imageRUNNER C3200 Copier
Network settings We have recently moved our c3200 and now the network settings have changed. I have configured the tcp/ip information and it still doesnt show up on the network - Help!
Make sure there is the standard settings like Domain...DNS.....Host name, gateway....Also make sure that the RIP on this machine is on and the cables are in the right place.
The correct procedure for the RIP is...Turn on the RIP then the Machine. IRC and CLC machine take a while to show up on a network when they have been turnt on. Also, you want to make sure the port you have plugged the machine into is fully connected on you switch box's
Posted on Apr 23, 2008
  • 87 Answers
Check your DNS server settings. Also, make sure you can ping it.
Bhai me Bhi Ek Week se Paresan hoo.
aap Hi Kuch Solution Nikalo to Mujhe Batana.
Posted on Nov 20, 2008
How could i change the ip addres my hp 4015n ?
Configure the network product View or change network settings
1. Type the IP address into the address line of a Web browser to open the embedded Web server. 2. Click the Networking tab to obtain network information. You can change settings as needed.
Manually configure IPv4 TCP/IP parameters from the control panel In addition to using the embedded Web server, you can also use the control-panel menus to set an IPv4 address, subnet mask, and default gateway. 1. Press Menu . 2. Press the down arrow to highlight CONFIGURE DEVICE, and then press OK. 3. Press the down arrow to highlight I/O, and then press OK. 4. Press the down arrow to highlight EMBEDDED JETDIRECT MENU, and then press OK. 5. Press the down arrow to highlight TCP/IP, and then press OK. 6. Press the down arrow to highlight IPV4 SETTINGS, and then press OK. 7. Press the down arrow to highlight MANUAL SETTINGS, and then press OK. 8. Press the down arrow to highlight IP ADDRESS, and then press OK. -or- Press the down arrow to highlight SUBNET MASK, and then press OK. -or- Press the down arrow to highlight DEFAULT GATEWAY, and then press OK. 9. Use the numeric keypad, or press the up arrow or the down arrow to increase or decrease the number for the first byte of the IP address, subnet mask, or default gateway. 10. Press OK to move to the next set of numbers. To move to the previous set of numbers, press the back arrow . 11. Repeat steps 9 and 10 until the IP address, subnet mask, or default gateway is complete, and then press OK to save the setting. 12. Press Menu to return to the Ready state.
Jan 14, 2011 | HP LaserJet P4015N Printer
Canon imageRUNNER C3200 Copier network setup parameter needed
Are you talking about creating a printer port in Windows to print to?
You can use a normal RAW 9100 port (just choose custom, and it will set it at that)
But I suggest setting the copier with a static IP.
By leaving it to DHCP, if you set any machine to use that address, if if "flops around" you'll lose the pointers to that address. Just go into the web interface on the copier to set the static IP.
Your question was just slightly confusing to read. I hope that's what you are asking for.
Aug 12, 2008 | Canon imageRUNNER C3200 Copier
Tip
Setting up (HP Jetdirect print server) Printers on a network
To install the HP printers with a built-in Jetdirect print server as a network printer you need to do the following -
1. Configure the HP's IP address using the printer's Menu options.
Enable the Network and configure the Network settings so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100, set the Subnet Mask to 255.255.255.0
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer to the network hub/router with a LAN cable and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to install the printer driver and configure the TCP/IP port for HP printer the same way on every computer on your network.
Now any computer on your network can print to this printer.
For detailed instructions on configuring the Jetdirect card, go to this WEB site.
http://printertechs.com/tech/tutorials/networking/networking3.php
on Dec 02, 2009 | Office Equipment & Supplies
Hi, I have two printer HP 4015n, I installed them on the same time in the same office (two month ago). They worked fine, but this morning all lights keep flashing ( both printer) and can't print. Any...
Thank you for contacting FixYa with your printer inquiry.
Sounds like both these network printers have lost connection to your router or failed to obtain an IP address after server maintenance or network upgrades.
Would suggest printing a configuration page on each of the printers and determine what the IP address is (If there is one) and see if other devices are in conflict. Power down your printers and reseat your Jetdirect Network Cards and confirm cable connections. Re-Power the printers and print configuration again to see if obtaining IP address.
Find out what IP address are to be assigned these printers and manually configure via embedded Web Server or at the printer control panel. Consult your manual or Follow these steps:
Manually configure IPv4 TCP/IP parameters from the control panel In addition to using the embedded Web server, you can also use the control-panel menus to set an IPv4 address, subnet mask, and default gateway. 1. Press Menu . 2. Press the down arrow to highlight CONFIGURE DEVICE, and then press OK. 3. Press the down arrow to highlight I/O, and then press OK. 4. Press the down arrow to highlight EMBEDDED JETDIRECT MENU, and then press OK. 5. Press the down arrow to highlight TCP/IP, and then press OK. 6. Press the down arrow to highlight IPV4 SETTINGS, and then press OK. 7. Press the down arrow to highlight MANUAL SETTINGS, and then press OK. 8. Press the down arrow to highlight IP ADDRESS, and then press OK. -or- Press the down arrow to highlight SUBNET MASK, and then press OK. -or- Press the down arrow to highlight DEFAULT GATEWAY, and then press OK. 9. Use the numeric keypad, or press the up arrow or the down arrow to increase or decrease the number for the first byte of the IP address, subnet mask, or default gateway. 10. Press OK to move to the next set of numbers. To move to the previous set of numbers, press the back arrow . 11. Repeat steps 9 and 10 until the IP address, subnet mask, or default gateway is complete, and then press OK to save the setting. 12. Press Menu to return to the Ready state..
Hope this helps. Please keep us updated and remember to rate this answer.
Nov 22, 2010 | HP Laserjet P4015x Printer
I want to connect my SCX 4500w to a new network (wireless). when i try to use a web page to configure the printer settings it doesn't response... I check the IP and write in in my Internet Explorer,...
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
Mar 07, 2010 | Samsung SCX-4500 Laser Printer
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
How do I change the IP configuration I installed a new network and need to change ip network from 192.168.1 to 192.168.0
Open network connections in control panel right click your adaptor and scroll down to properties and open then scroll down to Internet Protocol (TCP/IP) highlight and click properties once you are in there you can manually configure your IP settings.
If you do not have it already manually configured you will need to add your default gateway and DNS server (subnet mask is automatic once you click in the box). You can find this information by opening command prompt (start/all programs/accessories) and type in ipconfig /all.
Oct 28, 2009 | Canon imageRUNNER 600 Printer
C3200 Network Configuration
Is there a Fiery print controller on the lower rear of the machine? It is a small 10" x 12" box attached to the lower rear cover the network cable plugs into.
Aug 29, 2008 | Canon imageRUNNER C3200 Copier
Configure network card
i am a copier guy and was the first to train on the 3200 series network included this is not a copier problem
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
Canon imageRUNNER C3200 Copier Logo
296 people viewed this question
old marine
old marine
