Question about Cisco SPA504G IP Phone
No dial tone on cisco 504G phone
Trying to set up cisco 504G phone but can't get dial tone. we have comcast phone & internet service. i've plugged ethernet cable from linksys router to cisco phone. is this correct? any advice on a solution?
    Scholar:
  • 94 Answers
To use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Posted on Jul 23, 2010
Cisco 504g will not power up
Plug out the cable from this and put in again or reset the device.
May 08, 2014 | Cisco SPA504G IP Phone
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
I'm experiencing a problem with cisco 7941 IP phone. here is the current condition of the phone: it has no dial tone, the programmable button is alternately blinking, the headset button has a steady...
can you explain me how is your phone connect to internet.
best on your Question its seems to me you cant hear a dial tone because of following one or more factors might apply
  1. you must log into the Extension Mobility service
  2. you must enter a client matter code (CMC) or forced authorization code (FAC) after dialing a number
  3. your phone has time -of-day restrictions that prevent you from using some features during certain hours of the day
Sep 21, 2011 | Cisco 7940 IP Phone
Hello, I recently brought in a few Cisco 7961 VOIP phones into our office. The phones register when I first plug them in but when I pick up the handset to dial there's no dial tone. I tried swapping the...
You need to verify that the Cisco phones are obtaining the proper IP address from your DHCP server. You need to make sure that you create a DHCP Pool of addresses for the VoIP phones that you have and configure the DNS settings in the scope to point to your DNS servers and configure the router settings in the scope to point at the IP of the router. You may need to also configure the TFTP settings in the DHCP scope. Check the IP address settings on the phones that aren't connecting, if they are receiving a 169.x.x.x address then it is having problems reaching the DHCP server to get and IP address. Hope that helps to point you in the right direction.
Cheers!
J the Guru
Oct 15, 2017 | Cisco 7961G IP Phone
When trying to fax i am receiving the message no dial tone. i pick up the receiver to my phone and i hear the dial tone. is there a pne number to call for tech support.
Without knowing the exact model, I am unable to direct you to tech support....A common problem that causes this is either the phone cord is plugged into the out instead of the in jack on the back of the printer. Another possible situation is that you have VoIP phone service (comcast, or vonage) which doesn't provide a true dial tone for faxing, in which case you would need a dedicated phone line for the fax.
Sep 29, 2010 | Office Equipment & Supplies
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
Dropped calls, and no dial tone on Panasonic Dect 6.0 phone
I am sure that is a service related issue and no the phone itself.
Apr 26, 2017 | Panasonic KX-TG1033S Cordless Phone
DIAL TONE CONTINUES DOES NOT CEASE
Have you tried plugging and then plugging the phone back in. This should discharge all static electricity.
I had the same trouble once. If you are using a service such as Comcast Digital Voice, then restart all equipment (this apply's to VOIP services also). if it still persist then try a different phone. If it still persist then contact your phone company and explain all the solutions that you have tried.
Feb 04, 2009 | Panasonic KXT7885/-W Wireless Telephones
The phone does not have a dial tone,but the corded phones do
hi my phone does not have a dial tone. I've tried taking out my phone from the charger but its off
Dec 28, 2008 | Uniden 5.8GHz Cordless Phone
Faxing and receiving faxes
Hi, are you using the phone cord that came with your printer? If so, try a different cord if you have one. Can you plug a regular phone into that wall jack - does that work (dial-tone)? Are you using VOIP (like Comcast triple play), DLS or regular analog telephone service? If VOIP you may need to slow down your fax machine settings. Let me know how you make out. Good luck!
Nov 14, 2008 | HP PSC 2210xi All-In-One InkJet Printer
Cisco SPA504G IP Phone Logo
1,060 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
