Question about Toshiba Televison & Video
Have a toshiba 37AV500U, trying to get it to recognize computer. tried 15 pin RGB cable, no luck, tried s-video no luck.. help computer has nvidia GeForce FX5200xt agp 8x graphics card. tried to change resolution settings in computer to 60 htz and 800x600 res
Resolved this issue, bought a new rgb cable after three that I had did not work ....changed resolution setting to 1024 x 768.
all works fine...
Posted on Apr 24, 2008
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
How can i connect my pc to sony bravia kdl-40ex403
Things You'll Need:
  • 15 pin RGB cable
  • Audio cable
Step 1
Connect the RGB cable to the Video Out jack on your computer.
  • Step 2 Plug the other end of the RGB cable into the RGB jack under PC In on the back of the television.
  • Step 3 Hook up one end of the audio cord to the Audio Out jack on the computer and plug the other end into the Audio jack under PC In on the back of the television.
  • Step 4 Turn on the television and press the "Input" button on the television or the television remote control. A list of input options will appear on the screen.
  • Step 5 Highlight "PC" using the up and down arrow buttons and press the "+" button to choose the computer input. The television will display whatever is on your computer.
  • May 01, 2010 | Lenovo 3000 N500 Notebook
    I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
    The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
    Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
    If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
    Feb 06, 2018 | Sampo Computers & Internet
    I have a HDTV Samsung TV, Model #TXS3082WHX/XAA and I would to connect my desktop to the TV. Do you know what cables are needed?
    Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
    Good Luck !
    Feb 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
    The power is on. the computer is on. The screen
    You should specify exactly which L300(D) you have as there are over 30 variations
    Try this for starters.
    If you have or have access to a standard standalone vga/rgb computer monitor, connect it to the 15 pin female rgb port on the rear right side of your system to determine whether the system is providing a video signal and otherwise functional before proceeding further.
    You will have to select the external monitor from your keyboard's top row in combination with the function key.
    In some cases, where the video display proves non-functional, the latter becomes the solution
    We have to obtain video function in order to download this:
    07-28-2008Display
    Driver Intel Display Driver for Windows Vista (v7.15.10.1502; 07-16-2008; 20M)
    Mar 27, 2009 | Toshiba Satellite Pro L300 Notebook
    No RGB imput signal
    You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
    There is NO rgb connector on that monitor
    Good luck
    Dec 05, 2008 | Balance CM2015 15" LCD Monitor
    How do I connect my Laptop computer to my LCD TV?
    Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
    Apr 12, 2008 | Computers & Internet
    Samtron monitor color display 56V
    there are 15 Pins in Monitor cable which is connected to VGA port on the rear side of the Tower. First, we need to reset BIOS settings, and then try again - onboard video card only. for Add-on Video card try reseating video card in diff. slot if possible / reseat video card and try again. if it does not fix it, it could be the problem with Monitor RGB Connection - near the electron gun in the monitor CRT tube. resolder RGB , it will fix it.
    by
    Kasi M
    Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
    Televison & Video Logo
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
