Question about LG F1402FDS6 Front Load Washer
How to unlock lg front loader washing machine
taran_2005
  • 10515 Answers
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Posted on Jun 17, 2009
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
hi all you poor owners of this heap of junk, i have one too with the same problems, the shaking and moving around the bathroom was stopped by welding a 1/2 inch long piece of 1 &1/2 inch dia pipe to a 2 inch square flat plate of steel then putting double sided sticky tape beetween the plate and the floor
where you want the front rubber legs to sit, this stops it from running around the floor but it still needs to adjusted to have the
same on the front two legs to stop the shaking.by leaning the machine back a bit also helps to stop it leaking so bad while filling, it is only from the condersation from the hot water going in and the poor design of the soap drawer not allowing the water to run back into the washer which can be fixed by cutting the lip off
the bottom wher the drawer slides in then running a bead of silcone in the crack between the front cover and the inside piece
then another one on the front edge to run the water back into the washer. hpoe this helps. bryan.
Posted on Feb 26, 2008
SOURCE: front loader washing machine won't
Remove three screw at bottom of washer, pull of lower panel, reach up on right side just under the locking mechanism and bull ring down. door should unlock.
Posted on Mar 15, 2009
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
How you get my LG front loader to unlock door
Please supply the model number as the door unlock procedure is different on the various models.
Nov 17, 2015 | LG Washing Machines
How do I unlock door of LG front loader washing machine
If all else fails, use a length of taut cord to squeeze between the door and the water seal to pull back the catch.
Jan 25, 2015 | LG Washing Machines
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Have a lg tromm front loader and am wondering if it is ok to run regular detergent instead of the hd stuff. C.
Not recommended. When buying the correct product you should also find the front loader much more economical on washing powder than a top loader.
Mar 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front door does not release
press the pause/ play button. This will unlock the door
Jul 11, 2009 | LG WM2688H Front Load Washer
LG Tromm front loader-FE error code
The water overfills due to a faulty water valve. The valve needs to be replaced.
Sep 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front loader washing machine
This is normal, the unit usually goes into a SD or slow down mode. To stop this press the start pause button and the door will unlock.
Sgt 48
Jun 04, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG F1402FDS6 Front Load Washer Logo
600 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
