Stop looking and either replace it or check the resistance, ( but that isn't fool proof). Did you check the distributor cap itself? Could be cracked.
This was posted some time ago, but if you are still having a problem try checking the spring connector at the bottom of the coil and insure it is not grounding out against the breaker point plate retainer ring. I wrapped a small piece of rubber (old inner tube) around the retainer at the top and solved that problem. A little electrician’s tape should work if vibration doesn’t rub a hole in the tape. Another thing I found out is the screws holding the points to the plate get rounded on the underside and the points slip closed after running for a while and do not open properly. Each time I reset them and the tractor starts, it only runs for a while before it quits and the points were not opening again. I gave up and put in an electronic ignition and that solved all my problems. GOOD LICK!
