Question about Janome 4623 Mechanical Sewing Machine
Will not zigzaz neddle hits the foot plus the plate if u put it on #6 like it shows just bought the machine got it 4/21/08 please help
  • Janome Master
  • 1,388 Answers
If the machine is new from a reputable dealer, they should fix it for free under warrantee.
It sounds like the position of the needle arm swing needs guess is that is off centre and while one side hits the needle plate, the other does not....this is not a serious or difficult problem to fix.
Quick check is to set straight stitch and look at the "centredness" of the needle relative to the foot and presser bar, it will probably look slightly to one may only be a mm or two, but this can be enough.
A quick call to the dealer to explain and you should be sorted. I would not recommend attempting any home remedy on a machine that is in warrantee as it will void the agreement and if something serious goes wrong in the first 12 mths, you will have no recourse.
Posted on Apr 24, 2008
I know how to attach my ruffler foot but my needle keeps hitting the plate .what do I need to adjust to keep the needle from hitting the foot
You may need to move the needle position left or right. Try a different stitch length. If the ruffler foot is installed correctly and needle is in the correct position this should not happen. It is hitting left/right/forward or back of the ruffler needle space?
Sep 13, 2014 | Sewing Machines
Neddle hits hook plate+how to fix
check needle is straight and fitted correctly
Mar 06, 2014 | Singer CG590 Mechanical Sewing Machine
Singer Sewing Machine 534 repairs
hi it sounds like the timeing has moved on (1) and also on (2) would need to be seen by dealer.
Apr 09, 2013 | Sewing Machines
My neddle keeps bending the side and breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 03, 2012 | Singer 2732 Mechanical Sewing Machine
Neddle is hitting the strike plate?
sounds like the machine is out of time & needs to be taken to a sewing machine repair shop for repair
Feb 20, 2012 | Brother SE-270D Computerized Sewing...
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
How to thread kenmore3/4serger model 3851574192 i can't figure out the the green threading
most machines have a pictur of each thread color, study it and see if you can figure out which part the picture is showing. when done pull all threads to the left under the neddle plate and lower the needle plate and then turn the hand whell a few times to get it started, be for pushing on the foot pedal, this way you and see if something is not going right
Aug 27, 2009 | Kenmore Sewing Machines
Breaking needle
Sounds like the timing is off, have to take foot off, take plate off, put it in the zz position and using the hand wheel turn(with new needle in) and see where it is hitting feed dog, loosening the screws to the feed dog and moving it in the opposite direction out of the way so as not to hit. let me know how that works
Aug 08, 2008 | Brother LS-2125 Mechanical Sewing Machine
Janome 4623 Mechanical Sewing Machine Logo
54 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
