Question about Vacuums
I have a central vac beam model BM1372 the rug
I have a central vac beam model BM1372 the rug stick attachment has no power the hose has power and is working fine
  • 44 Answers
SOURCE: beam central vac
Don't know the exact model, but it sounds like the low voltage relay is stuck. This will be inside the unit, probably mounted on a replaceable board. You may be able to temporarily free it with a quick tap on the top of the relay if you locate it. But I would suggest replacing it to avoid further problems. mdvacuum.com would probably have the part you need. Good Luck!!
Posted on Jan 04, 2009
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Posted on Mar 27, 2009
  • 207 Answers
SOURCE: HOSE ATTACHMENT WILL NOT SEPARATE FROM VAC BODY.
How are you trying to remove the hose from the body?
With the DC-25, first you have to open the lid at the very top of the handle. Pull straight out on the aluminum tube with the red plastic part and the silver arrow. Pull it until the entire handle comes off the body. Once you do that, you click on the silver release mechanism. If you need further clarification, please let me know.
Posted on Apr 24, 2009
CorvetteKing
  • 108 Answers
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Posted on Jun 05, 2009
No suction when using hose attachments - motor runs and under cupboard vent works - just not able to use just the hose with attachments
does the vacuum turn on when hose plugged into wall outlet assuming your using central vac. if it does not turn on then the metal band in the hose end is possibly cracked.
Jan 03, 2015 | Vacuums
How do you put on the attachment hose to clean stairs
Assuming the rug nozzle is currently attached, lift up the headlight hood. Twist the belt lifter (black plastic square) on the rug nozzle counterclockwise to remove the belt tension. Then pull the accessory lock up until the rug nozzle comes loose of the Power Plant. You will notice two hinges at the bottom that hook on the the Power Plant's attaching bar. Gently lift up the rug nozzle to unhook it from the attaching bar.
Now your Kirby is naked. You will notice two small hooks on the hose attachment--hook them over the attaching bar, place the end of the hose attachment firmly against the Power Plant, then push the accessory lock down to clamp the hose in place.
You are now ready to use your Kirby with the hose attachment.
May 20, 2010 | Kirby Heritage II Vacuum
Carbon buildup on plug to hose causing burn
Sounds like there could be a short in the hose. Try another hose and see if that's the problem. It's too soon to have to replace the unit. Try having the hose checked out, it could be the root of your problem
Sep 03, 2009 | Beam Industries 2900 Serenity Plus Central...
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Problems with Beam central vac
My Beam central vac has started turning off after about 10 minutes of use. I thought it was the hose, but the hose in the garage does the same thing, and I've also tried the other outlets, and the same. The canister was just emptied about two weeks ago. I have also reset the breaker, and unplugged and replugged in the system. Could this be a bad motor?
Feb 22, 2009 | Beam Industries 2775 Serenity Plus Central...
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Vacuums Logo
126 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
