Question about Maytag 18.9 Cu. Ft. Top-Mount Refrigerator - White
Ice is clear get's jammed on rack
Ice is hollow and thin
  • 53 Answers
Make sure there is plenty of water to the refrigerator. It so replace the inlet valve.
Posted on Jul 23, 2010
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
My frigidaire gallery french door refrigerator is making ice very slowly. the water is coming out fine. It is only 4 weeks old. i got solutions from frigidaire from the valve to the water filter. Any...
The theory to making ice is temperature, water, and ice mold to function. What are the temperatures inside the freezer currently. It must be below 15 degrees to function and prefer the freezer to be at 0 degrees to product effectively. Are you ice cubes solid or hollow? If hollow you can jam the ice inside the ice maker causing slow production. Rare to have a water valve problem this young be is possible. I would look at temperatures first than cycle time to determine the next step. In a perfect world, your unit should drop ice every hour to and hour and a half.
Good Luck
Jul 23, 2011 | Refrigerators
I have a GE SS25ksta side by side refriderator. The ice maker makes ice, but the chute jams without fail. It is almost as if the ice doesn't weigh enough to push open the flapper arm at the bottom of the...
there's a solenoid that opens and closes the shute or the flapper.the part number is WR62X10055 and it's around 25 dollars.check around the plastic frame that holds this section of the dispenser in place,i'm pretty sure the frame pops off,you might need a putty knife or thin screw driver to pop it off,then you can get at the rest of the parts to change out the solenoid.it's self explanatory and easy to change it out once you pop off the outside frame piece
Jan 16, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
The ice maker is not filling the cube freezer and they are comining out paper thin when frozen
If they are hollow,You don't have enough water pressure going to the unit could just be a clogged filter also.
Aug 30, 2009 | Maytag Refrigerators
Making hollow ice cubes
Hollow ice is a sign of not enough water going into tray . Replace the water inlet valve (piece that the wall water line connects to on refrig ) .
Aug 29, 2009 | Refrigerators
U-Line co29ff, brand new unit. Makes clear, hollow, watery ice.
2 things you need to check. If you remove the icebucket look for armaflex the goes on the sensor tube from the icemaker to the back wall. If missing call U-line to get the correct one. The second thing you can do is check the icemaker control. Remove the grill, on the base in the right corner you will see a control with a screw. Turn the screw all the way to the right then back it so it will be straight up and down.That will set it cooler
May 10, 2009 | U-Line Refrigerator Ice Maker
Ice cubes are hollow.
some fridges are designed to make hollow cubes where they always hollow or just recently
Apr 13, 2009 | Refrigerators
THIN OR HOLLOW ICE
Freezer too cold and not much water. When it is empty of ice check the water level in the ice tray. Probably not even halfway up. Unplug fridge for 8 hours and plug it back in. Need more help please live chat. If this has helped, please rate as fixya.
Nov 19, 2008 | Whirlpool Gold Series GI15NDXT 15"...
Ice maker is not putting out ice GE
Low water pressure usually the cause of that, just like when you get hollow ice cubes as explained here:
http://www.applianceaid.com/icemaker.html#hollow (http://www.applianceaid.com/icemaker.html#hollow)
Jul 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Roper top freezer ice maker out of sync? Too warm?
sorry you must replace the icemaker.
Mar 30, 2008 | Refrigerators
Maytag 18.9 Cu. Ft. Top-Mount Refrigerator - White Logo
42 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
