Question about Dryers
Hi there. i have a whirlpool dryer and i believe my issue is the high limit cutoff. How do i fix this?
  • 53 Answers
Remove the back of the dryer. Test the limit and thermostat on the side of the heater housing. There is also a thermal fuse down by the exhaust it is white plastic with two wires check it as well as the heating element.
Posted on Jul 23, 2010
Dryer runs, no heat, element OK 10.5ohm, Hi limit thermostat .8 ohm, next one is thermal cutoff or operating thermostat, open no meter readings. Part # FSP 3399848 could this be my problem? Thank You
Both the Thermal cutoff and the operating t-stat should have ZERO ohms resistiance 0.8 is fine but open on either they are bad
That part number you have listed is what ya would need..even if only the thermal cutoff is open replace both the thermal cutoff and high limit t-stat at the same time
also if the cycling t-stat is open replace it too...if its fairly modenr and hasa digital display the cycling thermostat is a thermister and at room temp that will be about 5.8 thousand ohms
if has timer the cycling t-stat will look like the high limit t-stat and should be closed
GENE
Aug 29, 2011 | Dryers
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
Dryer shuts off before load is dry. it will not turn back on for about a half an hour. is this an easy fix?
Yes it is. It is more than likely your high limit thermostat. The high limit thermostat is located on the back of the dryer after the heating element, (right before the entrance into the drying chamber). They high limit and thermal cutoff usually come as a kit because they should be replaced at the same time. The thermal cutoff is located on or around the body of the heating element. good luck!
Apr 06, 2010 | Dryers
Hi, I have a probLem! No doubt you hear that frequently!! First, you need to know I'm 60, and not a mechanical or electrical bone in my body. I found this site as I was looking for a heating element for...
The two red wires on the dryer probably connect to the short red/wht wire at the end with the extra connector. The other end of the red/wht wire would then connect to the blk/wht wire with small brass connector. This arrangement should place the thermal cutout in series with the high limit (ie, one after the other). Suggest you post pictures if this doesn't sound right.
Feb 27, 2010 | Whirlpool LER8648P Electric Dryer
Whirlpool GEW9200L not heating up, i have replaced th thermal fuse, thermistor, heating element, thermal cutoff and high limit. What next.
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Oct 05, 2009 | Whirlpool GEW9200L Electric Dryer
Drum doesn't turn, but the light is still turns on. No noise indicating the electric motor is trying to turn the drum. I opened the top and verified the drive belt is intact and taut.
First, please keep in mind that i am attempting to diagnose your unit with out being there and with limited information.
If I were called out to your home to repair this problem, I would first check your breaker. I would flip it off and then back on. If this didn't fix the problem. I would then check the door switch. If it's good, I would then open the back and check the thermal fuse and then the Thermal cut off. If either were bad I would change it. If it were the thermal cutoff. I would also change you high limit because when the thermal cutoff is bad, it is due to the high limit thermostat going bad, then the dryer cycling on the thermal cut off until it goes bad causing a problem like what you have.
Please rate solution
Sep 08, 2009 | Whirlpool Dryers
Does not run or heat
check the high limit cutoff stat and if you see the igtn glow red and a click after the problem is in the gas valve
Sep 03, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
