Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front load duet washing machine. The white plastic around the drum is cracking and the machine is leaking from the front underside. Can this be repaired?
  • 15,935 Answers
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Plastic shaving in wash from ring around basket. What could it be. Model GHW9400PW0 Whirlpool Duet
k where they came off from so you can put them back otherwise it will leak. Inspect the inside of the unit while the tub is out (bearings, etc) to make sure there isnt anything else. Hope this helps!
Jan 30, 2013 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing machine is leaking on wash/rinse cycle. Hoses and plumbing is fine.
Check the soap tray for cracks etc & the input from that to the outer drum. Also seal to door.
To isolate the leak look underneath- is it at the front or rear or side etc.
Jan 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW9200SQ has knocking sound located under drum under or near motor. Knocks during spin up and down cycle and on last highest spin.
the problem is a cracked spindle on the back of the drum. It most likely also tore up the grey plastic front shield.The only thing to do is throw the machine out sine the drum cost parts onle is over $400 for drum, and over $400 for the front plastic.l
Nov 12, 2009 | Whirlpool GHW9200L Front Load Washer
The gasket has cracked on the bottom and leaks. I have bought the new door/drum gasket. Where can I find instructions as to how to replace this large gasket/ring that stops water from leaking out the door
This is not to my credit, but I found it on Fix-it--
here is an online manual ,as txt url wraps around you may have to copy paste it .
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washing machine
you see plastic shavings??? thats part of the front tub assy, not a very fun part to change call a professionnal for that one. in the meantime id pop off the lower acess panel and make sure all 4 of the suspension rods are in place and not causing the tub to lay foward and rub
Oct 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks out the bottom of door. metal ring with spring came off. put it back on and has leaked since
I have the same problem. I went to get laundry out of the machine and there is plastic piece with coded wires attached and metal tension that appears to go around the drum hanging loose. Probably have water but the machine is in the basement not too far from the drain. Mine is a duet 9100L about 4 years old
Oct 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal De
