Question about Runco CL-510LT Multimedia Projector
Menu on CL510 has password
I replaced the bulb but need to reset timer. however I can not get to the setup menu to reset timer. There is password prompt. How can I get past this. the last service guy that worked on it is out of business.
Hi use the cursor controls up-down-left-enter
Posted on Mar 22, 2011
Samsung R4266w turns off automatically. I've
Rest the lamp hour meter
  • 1 Press menu on the DLP's remote.
  • 2 Scroll down the list to "Timer."
  • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
Service Level Reset
  • 1 Turn off the DLP with the remote.
  • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
  • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
Aug 14, 2011 | Samsung Televison & Video
How do I reset the Lamp Timer on a Sony Wega KF-50WE620 TV?
Hello.
if you want to reset lamp timer on sony grand wega 50WE620...press menu on remote control then go to the setting you will find the setup button then press setup you will see the lamp replacement-start----yes and menu...
Thanks for using fixya
Caseytech
Jun 29, 2011 | Sony Grand WEGA KF-50WE620 Television
Hello, I was recording a timer program and the machine didn't turn off when finished. I pressed the timer record button and it stopped recording but a lock appeared on my top menu/title menu screen. It...
kdsmntnd
With DISH Network receivers, you can setup locks on the receivers to lock certain features. If you don't remember your password, you will need to call 1-800-333-3474, speak to Tech Support and they can reset the password. It takes about 1 hour for the password to reset. I hope this helps.
Ray Calo
DISH Network
Feb 24, 2011 | Televison & Video
Replaced bulb last nite, green light blinks for a min. then it worked! watched a few min.turned on this morning blinking.... wont stop green blink. last nite when i changed bulb tv said change bulb reset...
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Oct 16, 2010 | Panasonic PT-40LC12 40" Rear Projection...
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Apr 15, 2009 | Optoma H56 Multimedia Projector
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Lamp timer
the password according to the lg service dept is 7777
Jun 14, 2008 | LG RU-44SZ63D Television
Open Questions:
Runco CL-510LT Multimedia Projector Logo
334 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
