Question about GE Cooktops
Knobs won't turn
I dripped bleach into the inner workings of the knobs. After shorting out the electricity, eventually things dried out and the electricity came back on but now the knobs will not turn at all.
  • GE Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 18, 2010
Middle section ticking sound with sparking as if trying to ignite even though knobs
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
Short on Jenn Air electric stovetop
Dear Genie,
Well, you are right in your surmising!
That water has shorted out perhaps as many as several items.
One way to solve this problem would be to wait until the water dries up, could take days or a couple of weeks.
Another way would be to take a hair blow dryer and dry the parts by blowing them for a while, perhaps 10 to 20 minutes, but to see if that fixed it, you would need to turn it on, which could cause a short!
No good.
Best idea is to take it all apart and see if there is visible damage, and to take and electric meter and test it all.
God bless your efforts.
Jul 10, 2017 | Jenn-Air Cooktops
Burners are sparking when none of the burners are turned on and only stop when electrical source is shut off.
Water has gotten into one of the igniter switches (below the burner knob). Disconnect power, let it dry out for several hours, and things should work again just fine.
Jan 02, 2011 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
When turning on the burner, the gas does not always flow
There is usually a switch under the knob thaat controls the electrical sparker. OFTEN these get messed up when the area around the knob is cleaned and water gets behind the knob.
Dec 05, 2009 | GE Cooktops
Viking gas cooktop vgsu161-6b sparks continuously. There is no gas leaking. I spilled water on the controls and it is only when I turn on the 3rd knob from the top that this happens.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Short in knob
Replace the spark switch module on the bad burner.
Sep 29, 2009 | Amana AKS3040 Gas Cooktop
Problem w/ plastic knobs on JennAir electric downdraft cooktop
NO METAL KNOB FOR THAT MODEL COZ IF USE METAL EVERY TIME U USE IS HOT THATS WHY DESIGN FOR PLASTIC,MUCH BETTER TO U REMOVE THE KNOBS AFTER U TUNN ON THE HOBS TO LESS MELT THEN RETURN IT IF U TUNR IT OR ADJUST.
May 17, 2009 | Jenn-Air JED8230 Electric Cooktop
Boiling liquid ran down into ignition switch, now light stays on
is this the front right burner? i looked at one yesterday where milked spilled into it.it burnt out the little board under the know. i am not sure of the model # on the one i worked on.
Oct 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Hot Surface Light stays on
Our success has been to heat the elements to hot for about 5 minutes. Then let cool to reset temp sensor.
Can cause the problem by turning a burner on for a short period of time
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Electronic ignition
Alien, one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad. Catriver...post back.
Sep 23, 2006 | Jenn-Air JGC9430 Gas Cooktop
Cooktops Logo
83 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
