Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
How do I work this dam thing????? - Bissell 1699 ProHeat Clear View Upright Steam Vacuum
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
How do I work this?
Bissell 1699 ProHeat Clear View Upright Steamer
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The Bissell has a holding tank to the solution and the recovery tank for the water and soap you pick up -- -both are removable for cleaning purposes – there is a trigger assm on the handle to release the Bissell Soap or detergent that you are using – (low sudsing) and there should be a switch on the bottom of the unit to activate the revolving brushes. So the best way to shampoo the rug is to do it on the back pull – when you pull back you are dispensing the water solution and shampoo by squeezing the trigger assm, the brushes are agitating the carpet and the vacuum part is picking up the water. This is about as simple as I can get it – please refer to the owners manual for the trouble shooting part of the manual or check with your local vacuum cleaner dealer in your area and in the yellow pages under vacuums, or call the Bissell factory phone # or use the website.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac man
Posted on Apr 22, 2008
Why is there no suction coming out from the rectangular hole on my dyson
is there something blocked in the tube ?
there is a spring /metal piece in the handle of the rigid section and bigger items get caught up then it catches smaller items making a dam to stop the suction take of t he hose section and have a butchers or shine a torch to see first i had to release the blockage with a stick
Jul 31, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Stopped working - what could it be?
The first thing you should inspect is the power cord. Check it to make sure it is not damaged from the plug up to the vacuum. If it is damaged, you should replace it. If the cord checks out ok the next thing to check is the thermal switch located near the motor, not all vacuums are equipped with a thermal switch though. The thermal switch is a resettable switch, if it trips you can either manually reset it or it may reset itself. The last thing that you should check is the vacuum cleaner motor, If the vacuum still has no power it will most likely have to be replaced.
Dec 18, 2011 | Vacuums
No pads in shark purchased yesterday at walmart in ****** dam wi
return the machine to walmart and get another one. This just goes to show the care and quality control that they put into these sharks. (euro-pro products are prone to premature breakage and they dont offer any replacement parts) these are just disposable machines and a waste of money
Jan 06, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The vacuum turns on, but the thing with the bristles doesn't spin. Help?
no it can't be bypassed the motor is dc.the circuit board converts it from ac to dc
Apr 12, 2009 | Hoover U8145-900 Savvy Bagless Upright...
My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My bissell deep cleaner wont release water and cleaner into the flow indicater
do you mean the little red spinning thing?try unscrewing the clear cover , lift the red thing out and check for hair etc.then put it back together. worked for me, hope it helps.
Jul 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
NEED TO REPLACE VACUUM BELT.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=810092
Generic problem for all Vacuums
Posted by WFLAHERTY on July 20, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. One thing when you request to replace the vacuum belt, we need to know the actual brand name and model # of the vacuum in order to give you correct information on a how to change the belt, this is just an example of an average belt change. Generally you turn the vacuum upside down to see the bottom plate, and then you remove the bottom plate by screws, clips or levers. Then you can remove the bottom plate – if not then the top cover will come off instead. Then you can remove the old belt and install the new belt. 1st. hook the new belt around the brushroll pulley first, then reinstall the brushroll, then use a belt puller or a screwdriver with a hook on the end to pull or stretch the belt onto the motor pulley, then track the belt in a straight line until it is running in a straight line. then re-install the bottom plate or top cover. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Vacuums
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
131 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
