Question about Epic 450 Mx Treadmill
Epic 450 Mx Cannot adjust speed/programs and only start works and runs at .1.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
The console's keypad overlay is bad and the console will need replaced
Posted on Aug 13, 2010
I've got an EPIC 400 MX Treadmill and I can't get the speed to start, incline works, is it the keypad?
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 11, 2016 | Epic Exercise & Fitness
Treadmill flips breaker after staring up for about a second?
An overload causes the breaker to open. First: The motor might have a bad field winding or internal partial short: Second: A bearing on one of the rollers may be shot? You can check for this by simply walking on the tread. It should move, if not there is a bad bearing. A far out reason is that the breaker is opening at less than rated current. (failed breaker). If you have a long heavy duty extension #16 gauge wire (18 gauge minimum), try another outlet that you know is on another breaker.
Jul 01, 2014 | Epic 450 Mx Treadmill
Why does my treadmill not adjust speed? when i press any number it starts running but at a really quick pace. Also, if i put the speed as .5 it will stop.
RUN the software calibration go under the HOOD motor see the instruction, and fix it. see the speed sensor7f016ade-041e-4f50-8a39-9f81109c1be9.gif
God bless you
Jul 10, 2013 | Epic 425 Mx Treadmill EPTL88105 !
Comes on but will only go to #1 on speed! incline goes up but will not come down, unpluged and reset, however it stays in the same place. I did get the fan to come on! help
1) The main board control can be faulty, by worn deck belt
2)motor can be burn
3) Adjust the potentiomente in the elevation motor
4)lube the gear and shaft from elevation motor
5)gearing slips fix it.
5a) Run the calibration software for diagnose and troubleshooting
6) Tight the connector very well from sensor see the illustration.
Jun 01, 2012 | Icon Epic 450 MX Treadmill EPTL09605 !
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
May 08, 2012 | Epic 450 Mx Treadmill
We have a 600 mx and the pad is not working, the only button working is the start, i cannot increase speed or incline it either.
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Dec 14, 2010 | Epic 600 Mx Treadmill
Console to elevate and control speed does not work
you will need to test the red wire coming to the console with a volt meter to see if you are getting the required 9-12 vdc if you are replace the console, if not replace the controller. Now if just the buttons are not working replace the console. You can get a console from iconservice.com
Aug 13, 2010 | Epic 450 Mx Treadmill
Epic 450 Mx Treadmill Logo
309 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
