Question about Microsoft Office Professional 2007 Full Version for PC
I need to have 3 sections in a document. First, no page numbering at all. Second, roman numerals centered 1 inch (not cenntimetre) from bottom. Third, ordinary numerals at top right of page. how do i do this?
    Brigadier General:
  • 4,044 Answers
You use headers and footers to set these. You control location by specifying locations for these and you can specify Inches, Centimeters and Pixels. The header tool allows you to specify if either or both are present on the First page. Look under page formatting, and then in the header tool bar are the header / footer selections.
Posted on Jul 23, 2010
Roman numerals
Book indexing systems likely require such capabilities. That subject is in the realm of Nancy C. Mulvany (writer of 2005's Indexing Books); but good luck on getting a reply from such lofty heights.
Here is a page referring to how to sort Roman Numerals in Word tables: http://en.community.dell.com/support-forums/software-os/f/3526/t/17598900
Here is some code for sorting Roman numerals: http://stackoverflow.com/questions/6507536/how-to-sort-an-array-of-roman-numerals
Similarly, here is a discussion of use of vlookup: http://www.pcreview.co.uk/forums/sorting-data-using-roman-numerals-t2104212.html and also in the following Excel forum:
http://www.excelforum.com/excel-general/397231-sorting-data-using-roman-numerals.html
I doubt you want to use this online alphabetizer which can handle Roman numerals: http://alphabetizer.flap.tv/
Maybe I have misunderstood the question and you are wondering about something else besides sorting. But here is a link regarding some sql server sorting: http://sql.software.informer.com/download-sql-server-sort-roman-numerals/
Jan 21, 2015 | Games
Wants to give random page number in ms word
Not too sure whether your comment above is the problem or what you want to do.
Do you want to insert a page number, then put in non word doc pages, then have the next page in your word document numbered appropriately? If so, you need to insert a section break at the end of the page where you are going to put in pages, then make sure the page layout for the second section does not have "different first page" turned on. Now break any link between section 2 and section 1 in the page layout. So click off the "same as previous" icon in the footer in section 2. Then insert a new page number and set it to "start at" the page number you need it to be.
If you need several sections like this then just repeat the process.
Remember that if you delete a section break, then all the page formatting will revert to that in the previous section. Horrible but its what Word does. Go to the end of any document with sections and add one section break at the end of your text with the same page formatting as you want through the pages before you remove any section breaks in the document to avoid this.
There is a really good e-newsletter on Office issues, Woody's Office Watch; if you use Office a lot but find some features difficult to master, you'll love WOW, very helpful.
Sep 26, 2011 | Microsoft Office Professional 2007 Full...
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
How do i type roman numbers on a computer?
I think you are talking about bullet points, right? You have to start a list and right click on the number. Then go to Bullets and Numbering and select the type of Roman numerals you like (lower or upper case).
Nov 03, 2010 | Computers & Internet
1. Write a C program that converts a string
Here is a website that should be helpful...
http://www.novaroma.org/via_romana/numbers.html
Mar 17, 2010 | Office Equipment & Supplies
I have been trying to get Microshaft word 2008 for Mac to start page numbers only on page 3. I have a title page, a table of contents, and then the body of my document. I have created a section at the...
1. Place cursor in each section in which you want hide the page number on the first page.
2. On the Insert menu, click Page Numbers.
3. Clear the "Show number on first page" check box.
You may have to create a separate section for your Table of Contents to suppress the page number on it.
Nov 17, 2009 | Microsoft Office 2008 for Mac: Mac
My document has a cover and a table of contents. I want page numbering with one to start on the third page. I did do the page break for the cover and the contents and was able to start the document on page...
There are two ways to do this. The first way SOMETIMES works. If you don't have luck, try the second method.
Method 1:
  • Delete the page break between the end of page 2 and page 3
  • Position your cursor at the start of page 3.
  • Click on Insert / Break / Next page
  • Select all the text form page 3 to the end of the document.
  • Click on Insert / Page numbers. UNCHECK "show number on first page"
  • Click on <Format>. Make sure "Start at" is selected and the value is "1". Select <OK>
  • Select <OK>
Method 2:
You need to work with the headers and footers. When you are done, you'll have two different footer sections that are NOT connected.
  • Add a "next page" section break as you did above.
  • Click on View / Header and Footer
  • On the Header and Footer toolbar, Click on the icon for "switch between header and footer"
  • page down to page 3. Click on the "link to previous" icon on the header and footer toolbar
For some reason I occasionally have to do this twice to get it to stick but eventually it should work. The key is to make sure you have two separate footer sections; the first section is page 1 and 2 without page numbers then the second section (starting with physical page 3) that has page numbers starting with page 1
Sep 10, 2009 | Microsoft Word 2003 for Students &...
MY PRINTER DOES NOT LABEL IT'S Pages
What application are you printing from? Basically its the software that handles these features
Try this:
Please try the following:
1. Have your document up on your screen.
2. Click on "INSERT" "PAGE NUMBERS".
3. Select the options you prefer (as header or footer), (right, left, center, inside outside, etc.).
4. Make sure that these page numbers are not outside of the printable area or margin area.
If you are placing the page numbers as a footer:
1. Click on "FILE" "PRINT".
2. Click on "PROPERTIES".
3. Click on the "PAPER" tab.
4. Choose "MAXIMUM".
5. Click on "YES".
This will enlarge your printable area so that you can set your bottom margin as small as .12 inches. This will help in printing the page numbers as a footer.
If this does not resolve your issue, please contact Microsoft for further assistance. This particular issue is software related.
Apr 05, 2008 | Office Equipment & Supplies
Microsoft Office Professional 2007 Full Version for PC Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
