Question about Philips Universal PH301S Remote Control
Need codes for philips universal remote? SONY television
SOURCE: search codes for the remote to control my tv
My remote is a PHILIPS MAGNAVOX UNIVERSAL.. Inside is a number CLOO7. Problem is after putting batterys in I am to program remote with PM335 how do I do that? Hope someone can tell me .....Thanks
Posted on Dec 10, 2007
SOURCE: in need of codes for philips universal remote CL034
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Posted on Mar 08, 2008
SOURCE: philips universal remote codes for symphonics tv
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
Posted on May 30, 2008
aprmaejun
  • 97 Answers
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 18, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
Code for Sony tv using Philips universal remote 298095
Check these codes: 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Jul 08, 2012 | Sony Televison & Video
HOW DO I PROGRAM MY PHILIPS UNIVERSAL REMOTE TO WORK MY SONY TELEVISION , I NEED TO GET MY TELEVISION BACK TO CHANEL 3
What model is it? Most have an internal database of codes that you can program manually. Sometime the only way to program is via your computer. Philips has a call center that can help.
800-233-8413
Dec 13, 2009 | Universal Remote Control Philips Pronto...
I have a philips universal SRU3004WM/17 remote i
Sony 0 0 0 0 ,0 0 8 0 ,0 1 1 1
Please rate our help to keep the free service online++++Thanks fo using FIXYA
Sep 21, 2009 | Sony Televison & Video
TV code
Philips universal remote , it have code for that tv..
http://www.urc.philips.com/
May 23, 2009 | Westinghouse SK-32H240S Television
I need the code for a Philips SRU3006WM/17
Codes listed for Sony DVD players are 0300,0400,0500,0541,0200,0540. Hope this helps due to no listing for Blu-Ray players.
Mar 29, 2009 | Universal Remote Control 6-Device...
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Feb 17, 2009 | Proscan 32LA30Q Television
Need codes
i have a sylvania tv with a ge universal remote control
Oct 02, 2008 | Televison & Video
Televison & Video Logo
257 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
