Question about Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
Where can I find a replacement globe? - Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
    Genius:
  • 1,970 Answers
Mcdevito75 here, You should be able to get a replacement globe at most any store that carries ceiling fans.
Posted on Jul 23, 2010
Low beam headlight not working
check globe - Could be element blown on low beam part of globe. A lot of globes are haligon globes with two elements my low beam filament blew two weeks ago and I just replaced the globe but if you look at the globe you will see one of the two filaments is vapourised (missing) if blown.
Aug 13, 2014 | Cars & Trucks
Replace park bulb.vt commodore
To replace the front parklight globe on a vt commodore can be a little tricky.
1.turn the lights on to see which 1 is inoperative once you know turn lights off.
2.open bonnet
3.go to side that is inoperative and on the back of the headlight you will see a round large plastic cover turn this to release it.
4.under the headlight globe there will be 2 wires flow these to the park globe socket gently twist and pull it out.
5.once the sockets out and you can see the globe ,pull the globe out of socket.
6.push new globe into socket
7.refit the socket in headlight
8.refit all trims
9.turn lights on make sure new globe is work..
Jan 22, 2014 | Cars & Trucks
My interior lights are dim how do i brighten them
Have you recently replaced the globe? is there one or two globes in the fitting? If it's a 2 globe fitting, one may be blown. If you've recently replaced a globe, you may have put in a lower power rated globe than the original.
Oct 09, 2012 | 2001 Hyundai Sonata
The light on the auto shift inside my suzuki sidekick is out, at night you cant see where the reverse or any gear is at..how do i fix this
Sounds like the light globe has failed. To replace globe you will have o remove the cover over the shift lever to gain access to the globe socket. Once you have removed globe, replace it with the same type and wattage (usually 3 to 5 W) and then replace cover.
Jan 07, 2011 | 1997 Suzuki Sidekick
How to replace heahlight bulb in a 1994 Audi What bulb do i purchase? How do i release the clip that holds the light unit in place?
I replaced my globes not so long back.
The metal clip you simply push down. Replacing the left light is challenging as the air intake is in the way but its not impossible. After removing the clip there is a plastic cap. Remove it.
Then remove the cable that feeds power. You should be able to see the rear of the 'globe'. There is another spring loaded metal clip holding the 'globe' in place. Push the two ends of the clip together to remove this clip. The globe should be free now. Remeber the globe go in a specific way, so take note. I bought to Halogen globes for my Audi as these immitted a stronger beam. Please, whatever you do DO NOT TOUCH THE NEW GLOBES GLASS. The natural oil from your fingers will impact the lifespan of these and you'll have to replace these again. Remember to also reallign the beams.
May 26, 2010 | 1994 Audi Cabriolet
Need new globes on lights
Go to lowes or home depot as both places carry replacement globes in stock. They can also special order for you. Bring in one of the old globes to be sure you get a perfect fit.
Apr 28, 2009 | Westinghouse Helix 78794 Chrome Finish...
Light Globes
You have 12 volt globes that are 50 watts power. Check out a home improvement store/lighting store for a replacement.
Sep 11, 2008 | Camping, Backpacking & Hiking
89 Pulsar Headlight
you need to replace it from the back, if its not accessable try removing afew things if not remove the entire headlight as it must be fitted from the back.
May 23, 2008 | 1989 Nissan Pulsar
Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Dec 12, 2007 | Refrigerators
Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan Logo
76 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
