Question about Razer Barracuda Gaming Headset
Mic Problem Hello the razer barracuda headset mic is detachable, i can use the mic when connected through the pc. (not when connected via headset). So the mic must work. The LED indication light for the mic on the headset does turn on when the mic cable is plugged in. How can i fix this and plug the mic into the headset where it should be? The mic is no good directly plugged in to my pc because i have to kneel beside my pc to speak.
  • Mark Miller
    Mark Miller Dec 02, 2012
    im having this same issue please email me at markmiller@myself.com if you found a soultuin
2 Suggested Answers
fdlixboy
  • 79 Answers
SOURCE: speakers feedback through my Barracuda Mic
if have a camera already connect on your pc try to unplug the mike of your camera or go to the audio device manager and change the settings.
Posted on Jul 07, 2009
Philips shm1900 headset on Lenovo thinkpad t430 with windows 7
It sounds like you are still using the mic on the laptop. Because you are far away from it, it sounds like echo.
Make sure the phillips headset is selected in the Windows mixer.
Make sure you are plugged into the mic jack on the laptop.
Make sure the mic is not muted. This is a default setting.
Apr 02, 2014 | Philips SHM1900 Headset
LG Headset can pair with PC and I can hear but the mic is not working
I have this sale problem. I am using a rocketfish micro dongle to connect my LG tone to my PC and I can hear fine. However, when I set the bluetooth mic to default, I only hear these random blips and pings and it shows nothing received in the audio bar.
Feb 04, 2013 | LG hbs-730 Tone Stereo Bluetooth Headset
Mic won't work at the same time with the audio?
Your trying to separate two audio sequences with one through cable the head set is not designed for the standard input jacks to combo they are isolated. You may need to get a mic and headset that has two cables one for the "Pink" and one for the "Green" input to do both. Maybe someone has a better answer or some trick to be able to get two audio signals to work at the same time with one input.
Apr 11, 2012 | Computers & Internet
How do I tighten a loose earpiece?
The whole thing is probably plastic and subject to breakage if you're not careful. I've found that gentle pressure on plastic pieces works most times. But--that's the trick. How to get just the right pressure. I'd sure try it, but be careful. Glueing that type of plastic is very difficult. It can be done, usually, by melting the pieces together with lacquer thinner.
Dec 08, 2011 | Razer Carcharias Gaming Headset
My head set just stopped working no sound, mic dosent work or anything, plugged in a second headset to make sure it wasnt the jack, definately something wrong with the razer. any suggestions? where do i...
Possible that the wires would have wriggled off from the jack side due to some ****. to confirm you will need to check one by one afteropening the sides,the continutiy of the wires to the jack and to the mic.
if ther is no continutiy replace the wires and jack. You can also dissect the jack to get to the problem and patch this up after finding the open wire. Ok
Jul 01, 2010 | Razer Carcharias Gaming Headset
When I go into chat I can't get my sound to work.
did you connect a mic headset? Without the mic headset, there is no way you can get sound.
Good luck.
Apr 25, 2010 | Dell Studio 17 Laptop
When i turn the volume up or down i get a static noise, and when I try to use the microphone i get no response. I know the sound is working because i can hear music with static, but the microphone doesn't...
The static noise may be caused by dust! To clean it out spray some Servisol video 40 into the volume control and move it up and down. If it goes away it was just dust.
The mic is another thing. The only thing I can think off ist that it's got switched off somehow on your laptop. Or either the control panel slider for microphone input is set to low?
You can get Servisol from Radioshack USA or Maplin UK or that type of shop.
Nov 28, 2009 | Razer Barracuda Gaming Headset
Speakers feedback through my Barracuda Mic
Jul 06, 2009 | Razer Barracuda Gaming Headset
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
Feb 20, 2008 | E-Machines eMachines Refurbished EMA...
Razer Barracuda Gaming Headset Logo
67 people viewed this question
Top Razer Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Razer Radio Communication Expert? Answer questions, earn points and help others
