Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The blower pulley on our dryer keeps coming unscrewed from the shaft it is threaded on. Should I use locktight to hold it on?
4 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Posted on Jan 25, 2009
  • 65 Answers
SOURCE: Can't remove dryer blower wheel
I would start by taking off the top and checking the belt to see if part of it tore and is hitting the inside of the cabinet. I have not found a real good way to get the blowers out without having to break them sometimes. the part of the blower that you have to hold is access through the front behind the motor. problem is when you turn the motor shaft, the wrench strips out on the blower, then you have to break them, but unless you need a new motor, it should not have to come off.
Posted on Jan 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: where can i buy motor pulley for performa dryer? mn pdet910ayw
Belt tension pulley assembly
This is a RSPC dryer (SQ/Amana)
SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 19, 2012
We have a air flow problem but exaust tube is not clogged no air coming out of bottom of dryer
On this weird dryer the blower is not mounted to the motor. Instead a fancy blower is mounted away from the dryer and requires a second smaller belt to drive it. What goes wrong? The drive pulley for the blower often falls off the motor. Locktite is recommended to keep the blower pulley secure to the motor shaft or this will be the result:
MAYTAG 2 BELT dryer innards
Aug 10, 2012 | Whirlpool Dryers
Motor heats up and stops running how do remove
The blower fan on this model has reverse threads where it screws onto the motor shaft. At the small space between the motor and the rear wall of dryer you will see that the blower wheel has a square neck that will allow you to hold it stationary with a large crescent wrench. while holding the blower grip the pulley on the front of the motor with another wrench (or channel locks) and turn the motor shaft clockwise to break the blower loose. Sometimes a quick motion is better to free it as it may be on the motor threads pretty tight.
Good luck on this!
Jul 11, 2010 | Whirlpool LER7646E Dryer
How do you remove blower wheel from the motor?
i grab the motor shaft with wrench and with a 1/2 inch rachet extension. and remenber its reveresed thread
Feb 07, 2010 | Dryers
How do you get the motor off of a whirlpool dryer? We are trying to replace the bulkhead, but can't get the motor and blower separated
The blower will be held to the motor shaft by one or two allen set screws. Loosen these screws and the motor will pull out. the blower fan will drop down so make sure you can somehow hold it while you pull the motor away. Obviously unbolt the motor from the chasis.
Hope that helps.
Jan 16, 2010 | Whirlpool LER6611L Electric Dryer
How do I remove the pulley from the motor of my Hoover 5010D dryer to put onto a new motor?
Take a big tough wrench and put on shaft next to blower wheel. Now place a big tough wrench on the slotted place on the blower wheel. A place for a wrench is located on the blower wheel where the motor shaft goes into the wheel. Now holding one, try turning the other. Make sure you don't have one that has reverse threads. There are some models that do have them. They drive me crazy trying to determine which it is. They are normally real tight. About 1/3rd of the time I end up having to bust the blower to get it off. Although try not to if you don't have to because this is a part that seems to never go bad.
Please rate solution
Aug 28, 2009 | Hoover Dryers
Pulley on alternator comes loose
souds to me as though the bolt is shot, and possibly the thread in the shaft. If this has happened again after correct attention you should be seriously looking to strip and rebuild, even Locktight wont heal "wobbly gear shafts".
Mar 24, 2009 | 1998 Triumph Trident 750
Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Dec 28, 2008 | Kenmore 63942 Dryer
I am trying to remove and replace the motor on a whirlpool dryer. i bought the unit new in 1994. i can't seem to get the motor shaft loose. i am trying to turn the shaft in the clockwise direction and with...
check the end threads of the new motor are the not left hand threaded, if so you are tighhtning turn the oppisite direction
btw you may have to replace the blower if it cracked the blower when the plasitc came off might have to use vise grips to ge it off
Apr 26, 2008 | Dryers
Gallery gas dryer
one of 2 ways, diagram wasnt very helpful. the blower wheel either is threaded on the motor of is held on with a clamp. the clamp obviously undo and the motor will slide out, if its threaded look closely around fave of wheel you will see the words remove, with arrows if the direction to turn. Some are reversed thread. in which case you need to hold opposite side motor shaft with correct size wrench and unscrew from front( you wont have to completely remove the blower from housing it'll come forward enough to remove.the motor itself is held in by 2 plastic hold downs one in front and behind the motor.
Mar 15, 2008 | Frigidaire FGQ332ES Gas Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
143 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
