Question about Palm TX Handheld
File locked MY DESKTOP IS INOPERABLE.  I GET A MESSAGE THAT SAYS  "FILE IS LOCKED"
I get this message sometimes when working with Excel spreadsheets. What I found out is that I had a bad formula between worksheets and the Palm didn't know what to do with it so it locked the file until I fixed it on my desktop and resynched.
Posted on Aug 21, 2008
  • 2,794 Answers
You will probably have to erase the memory to the TX and reload the software to fix it.
To erase the TX memory, press the reset button. At the boot screen hold down the power button. Confirm deletion. Reload software from CD.
Posted on Jun 09, 2008
Need to unlock obsolete document to throw it away (iMac).
Put the file into the trash as normal then..Hold down the Option key (Alt key) and select empty trash while holding it down. You won't get any warning but the trash will empty and your file will be gone.
Dec 29, 2012 | Apple iMac G5 Desktop
Need to find out how to unlock my password for my dell 2400 desktop
I forgot dell password, i just reset the password by the following steps,
Step1.Download Smartkey Windows Password Recovery from recoverlostpassword.com and decompress it on that PC. There is a.ISO file. Burn the .ISO file to CD or USB Flash Driver.Step2.Get out the newly created CD or USB Flash Driver and insert it tothe locked computer.Step3. Re-boot the locked computer and then follow the process ofinstructions. Just after a few steps, the old password will be removed.It can recover all Windowsversion.
May 17, 2012 | Dell Dimension 2400 PC Desktop
Hp workstation wx8200 locked up and now won't power back on, red power light blinks 9 times and stops, then 9 more times and stops.
PDF File
Try downloading the file above and see what it says.
Should you have questions, regarding the file above feel free to approach us.
May 12, 2010 | HP WX8200 (DU935AV) PC Desktop
I have Quicken 2007, MAC. Getting error message" "File is locked, transactions will not be saved" Never had this before.
This is due to a corrupt file. If you have a backup on .MAC or on your disc, open the older file. You may need to update transactions, etc.
Dec 04, 2009 | Intuit Quicken Mac 2007: Mac
Cannot "save" quark 6.5 files, have to "save as" and rename
Have you tried the following
it could be that the file is locked go the file and single click on it go to the file menu and select get info. see if the file is locked, if it is unlock it
or do a "save as" in Quark and rename the file
it may be that when you have transferred your files that the permissions are not set properly. do the same as the file is locked above but look to see whether you are the owner and whether you have read write permissions. If you don't change or add yourself as the owner.
Hope this helps.
Nov 24, 2009 | QuarkXPress 6.5
We are experiencing issues within the AS-5000 transcription software for our Olympus DS-5000 recorders. When a typist selects the status of the file (''pending'', ''finished'', etc.) an error message pops...
This is a know issue of the initial releases of DSS Pro 5. Downloading the update (using the Update option inside the software) will not really fix it, but will at least give you an option to override the Locked status. This "fix" appears from update 5.0.5
Jun 04, 2009 | Olympus DS-4000 Digital Voice Recorder
P6 locks up when opening a project
The software knows whether the file is in use by creating a "lock file". When you "fix" a locked file it usually means the software deletes the file that prevented access your file/document and not that it dropped the user currently using that file instead of you. The software only allows you to fix a locked file, because rarely the software makes a mistake and does not clear the lock file. While it assumes you've verified you're right and it's wrong. In my experience, the file is actually in use either by a system process, through a remote account, or by a user you just couldn't locate. The software locking up when you force the deletion of the lock file is always the result of a read/write error. This is usually a good indication two sources are in fact trying to utilize the same file.
Dec 08, 2008 | Computers & Internet
A file corrupt message: This script cannot be found or has been d
you can try a program called 'unlocker'. if that doesn't work, then you could try renaming the file.
Nov 26, 2008 | FileMaker Computers & Internet
Locked file
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
Jun 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Phone locked! Please Contact service center!
My phone is giving message Phone locked! Please Contact service center!)
Dec 31, 2007 | Haier D6000 Cellular Phone
Palm TX Handheld Logo
66 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
