Question about ScanSoft PaperPort Deluxe 9 (6809A-G00-9.0) for PC
I am attempting to install Paperport 9 on my new computer that has Windows 7 ultimate as the os. The message was that i had a driver compatibility issue.
  • 3 Answers
Use Windows 7 feature that emulates XP.
Posted on Aug 25, 2010
I have a CD of PaperPort Deluxe 9. Now I have windows 7. How can I upgrfade PaperPort to work?
PaperPort 9 won't work on Windows 7. I tried compatibility mode and it still doesn't work. If you have a son or grandson in full time education you may be able to buy PaperPort 14 from www.software4students,co.uk for a very low price.
Jan 30, 2011 | ScanSoft PaperPort Deluxe 9...
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
How can i install hp deskjet printers in my pc with OS windows ultimate 7?..
Hi. First things first is make sure that the printer is compatible with windows 7 Ultimate. You can search/download the printer driver at HP website. Install that driver then plugged in the printer to your computer.
Oct 14, 2010 | Computers & Internet
I need to find a driver for HP Photosmart C6283 for my laptop cause i can't install it to windows 7 ultimate... and the message error is "The software is not compatible with the OS" Please help me to fix...
The 64bit drivers are below - I suspect you have windows 7 64bit installed on your PC and thats what its complaining about http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=sg&dlc=en&sw_lang=&product=3308700
the other drivers for different windows versions are also available from that link - just change the OS at the top
Sep 28, 2010 | HP Computers & Internet
It will not work with windows 7. Is there
Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all This should all be done in Administrator Mode. & done to BOTH the install .exe and the programs run .exe
Mar 05, 2010 | ScanSoft PaperPort Deluxe 9...
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
Feb 19, 2010 | ScanSoft PaperPort Deluxe 9...
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
PaperPort will not open when i try to open it
Microsoft's Groove Folder ruins Paperport.
If you have included Groove Folder when you installed Microsoft Office Ultimate 2007, you will need to remove it ASAP.
Start/ Control Panel/ Add or Remove Programs/ Microsoft Office Ultimate 2007,
then deselect the Grove Folder component to make it a red "X", and let windows do it's thing.
It will take about an hour (!) for windows to unhook this VERY bad software - but Paperport will run again when you are done.
Be sure to set a new restore point for your system after you reboot and test Paperport.
Jan 27, 2009 | ScanSoft PaperPort Deluxe 9...
ScanSoft PaperPort Deluxe 9 (6809A-G00-9.0) for PC Logo
198 people viewed this question
Top ScanSoft Computers & Internet Experts
vsri9
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
