I installed a printer i already used and now it don't want to print. i don't have the cd, is there anyway i can download it?
I DON T SPEAK ENGLISH . AR YOU SPEAK FRENCH?
Posted on Apr 22, 2008
A friend gave me her HP psc 2210 AIO. She did not have the owner's manual. I have it hooked up. It turns on, but won't print. I need the operating instructions to get it going. I have a newsletter...
Hi Peggy,
Have you already installed the printer driver to your computer? This is one of the first things you should do when installing the printer aside from hooking it up to your PC. If you don't have the driver don't worry because you may download it by clicking on this link. Then follow the steps below:
1. Select your operating system (ex. Windows XP) then hit on Next.
2. Afterwards select Driver Product Installation Software.
3. Then hit on Download.
4. Once driver is downloaded, install it .
5. Lastly, restart your computer.
For your instruction manual download it from here.
Hope this helps.
Thank you for using FixYa.
Oct 23, 2011 | Office Equipment & Supplies
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to install brother mfc 420cn
In order for your printer to work, you need a Software Installation CD (If you don't have it, you can found it on internet as a "driver" or "software"). For your model, click HERE , download this driver and then install it.
I hope I helped you!
May 15, 2011 | Brother MFC 420CN All-In-One InkJet...
I can not get the printer to print
I am assuming you are trying to print from a computer, not a photo memory card (SD Card).
Try the following things:
- get the manual and install CD if you have it
- use the manual or the menu on the printer to print a test page (if that works then it is probably not the printer)
- make sure the USB-B cable is connected
- Start the Print Manager software on your computer (install it from the CD if it is not installed already, download the drivers from on-line if you do not have the CD)
- Use the Print Manager to print a test page (If this works, then we know the cable works)
- in Control Panel under Printers select the Epson Stylus as the DEFAULT PRINTER
- from the application (MS Word, Photoshop, etc.) try printing and verify that the Epson is the selected printer
If this does not work please provide further details about what hardware and applications you are using and what you are trying to print.
Good luck. Bry
Jan 01, 2011 | Epson Stylus RX580 InkJet Photo Printer
Havng a problem installing lexmark 4350 printer on windows vista ? 3.5 hrs and still nothing will print ?
Is the Lexmark software already installed in your Vista computer? What did you use to install the sofware, the installation cd or the downloaded file? Did you get any particular errors when installing?
Are you getting any error when printing?
Apr 28, 2010 | Lexmark P4350 All-In-One InkJet Printer
Not able to print from windows 2008 server 64 bit but able to print from xp clients
Install Addtional Print Driver --x64 bit from Printer Properties----require first to download Print driver from vendor website or if you already have this driver on CD, insert disc to CD/DVD ROM while installing
Apr 27, 2009 | HP Color LaserJet 3500 Printer
Re: DVD labels won't print on my Epson R265
Hello guys.
About the problems printing CD/DVD with your Epson R265 ....................
There is nothing to do. The prg coming with the printer (PrintCD) is wrong at all and we cannot understand why the Epson Corp. has simply deleted the prg by its download site.
After tryng for a lot of solutions ........ INCREDIBLE but TRUE ..... the program Print CD coming with the previous Epson R200 is ok at 100% !
So, in conclusion, all prgs inserted onto the Epson R265 CD are OK eccept the Print CD. Don't install it from the R265 disk ! It will crash !
If already installed, delete it and install the prg Epson R200 print CD.
It will work fine and without troubles.
Repeat ... it's incredible, but true.
The prg can be downloaded searching for Epson R200 software.
If you will have troubles, let me know.
Aug 23, 2008 | Epson Stylus R265 InkJet Photo Printer
Printing CD on Espon R260
I have a new G5 Mac. I downloaded an updated driver from Epson and then clicked on Update Printer Information. I had failed earlier to click on this button after downloading the new driver.
Apr 18, 2008 | Epson Stylus Photo R260 InkJet Printer
My fax instructions are in german. I need the english version
Thanks for getting back so quickly- I have already solved the problem so thanks anyway! I just had to install it with the CD. and followed the prompts . It was all installed in english. :-)
Mar 10, 2008 | Lexmark X1240 All-In-One InkJet Printer
HP 1315
You should have gotten an installation CD with the printer. First, find the installation CD. Once you have that, follow the steps given by the tech.
Apr 25, 2007 | HP PSC 1315 All-in-One Printer
50 people viewed this question
jasbo
jasbo
