Question about Kodak EasyShare CX7330 Digital Camera
When i turn camera on camera error #E45 shows up on display and lens will not open up
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
My kodak v705 always show a error e45 when we turn on what will i do to fix my camera?
This is not a good error to get. It means the lens is stuck. For people where the lens is stuck open, sometimes they fix it by tapping or slapping the lens while turning off. But you say when turning on? You can still try the tapping trick to free what is stuck. It's not very useful advice but it's better than you'll get from the Kodak website
http://faqs.kodak.com/101_en/FAQ_96_10328.shtm
which pretty much says "you're screwed, you'll have to send it to us to fix it".
Or words to that effect.
Feb 16, 2011 | Kodak EasyShare V705 Digital Camera
Turn on and it displays code E45
Its a LENS error. Remove the memory card forfat it then insert after 15 minutes. Now Turn on & try.
Jul 20, 2010 | Kodak EasyShare CX7430 Digital Camera
Camera locked - camera error #E45
Hi
www.Kodak.com says:
"E45" appears on your camera's display when your camera requires service or repair.
I think it is a lens error. They have a page on www.kodak.com called Step-by-Step Solutions and Repair. This is for USA only.
See what they suggest.
I may be cheaper just to get a new camera.
Hope this helps.
Feb 21, 2010 | Kodak EasyShare LS753 Digital Camera
It shows Camera error 45 what to do?
The Error 45 report you have seen on your camera is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error. Update the firmware and the error should go away
Dec 24, 2009 | Cameras
Camera error e45
Commonly for most Digital Camera "E45" appears on your camera's display when your camera requires service or repair. Issue is related to its lens. Solution is to contact your camera Manufacter.
Nov 12, 2009 | Cameras
My camera kodak easy share v530 has error e45 the zoom doesnt go in when i turn it off. when i turn it on it says error e45
E45 means it has a lens error., the gear of the lens is already defective you need to call precision camera for repair toll free 1 800 665 6515
Nov 01, 2009 | Cameras
Turned off camera, opened hatch to battery and memory card too quickly. Turned on camera Error E45 displayed on screen.
Hello
Regards
Andrea
Apr 18, 2009 | Kodak EasyShare V610 Digital Camera
Error E45
Turn your camera on and smack the camera against your hand. The E45 error means your lens is stuck. The lens on my V603 was stuck open, when I smacked it against my hand it closed and now works fine. Give that a shot.
Jun 23, 2008 | Kodak EasyShare V603 Digital Camera
Camera error # e45
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following the procedure below..
it may be the lens contacts or grit in the gears
open it up on the side of the lens you will see a row of thin gold coloured contacts that report the lens position back to the cpu sometimes these get dirty or bent.on the side of the lens is a motor, look where the gear meets the lens and use a pin to flip out any grit that is stuck in the teeth.
Its very unlikely the lens is "out of alignment" this just cant happen unless its been dropped or bashed, in which case it may be broken.
Also i have heard some people bashing the camera a couple of times to get it working..
hold the camera and bash the edge next to the lens against the palm of you hand as hard as you can, one I did have to get a little more medieval on and bashed aginst a bit of carpet on the bench.. but it worked... might be worth a go if the next step is the bin...
Nov 01, 2007 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare CX7330 Digital Camera Logo
70 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
