Question about Acer Aspire 5100 Notebook
LCD INVERTER (I HAVE TO CHOOSE THE ACER ASPIRE 5100 TO POST IT) I BOUGHT ACER LAPTOP MODEL 4620-4650 SIX MONTHS AGO. I HAVE TO CHANGE THE SCREEN BECAUSE WAS BROKEN IN AN ACCIDENT, BUT THE LCD INVERTER IS NOT WORKING PROPERLY SO MY QUESTION IS THE FOLLOWING: CAN I BRING THE LAPTOP AT YOUR SERVICE CENTER TO BE FIX IT? DOES THE WARRANTY WILL COVER THE SERVICE? (ACER CUSTOMER SERVICES SAID YES IT WILL) OR DO YOU HAVE THE LCD INVERTER TO BUY IT IF THE WARRANTY DOES NOT COVERED? tHANKS
    Sergeant:
    Champion:
  • 244 Answers
FYI,
If your lcd is cracked, your warranty is gone. It doesn't matter if it is accident or not, because it is user fault. Unless you have 3 year total warranty from acer, they will repair it.
Posted on Apr 22, 2008
My acer aspire 5517 laptop green blank screen and changes to red every 4 second!
More than likely the screen Inverter, Anowarul.
http://www.amazon.com/Acer-Aspire-Series-Inverter-Board/dp/B006BHRG9E
However the problem should be diagnosed.
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter
4) LCD screen
I have a diagnostic flowchart you can follow, if you wish.
Post back in a Comment.
The plastic frame in front the LCD screen is the Display Bezel.
(Acer? LCD Bezel)
Once removed the screen Inverter is right there in front.
Mounted to the bottom of the LCD screen's Screen Frame.
Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to where it states - Aspire 1200 (1200 in Blue)
Drop down to the 7th line. (5310G)
Scroll across, and click on 5517.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Regards,
joecoolvette
Mar 19, 2013 | Acer Aspire Computers & Internet
White screen but plugin monitor works. is it the screen?
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5100/Aspire5100sp2.shtml
http://www.laptopscreen.com/English/model/Acer/ASPIRE~5100/
So you PHYSICALLY checked the connection of the Video Cable, TO the motherboard, TO the screen Inverter, and TO the back of the LCD screen?
Visual inspection will NOT do. If either motherboard connector, or LCD screen connector is loose, the width of this letter -> I < you won't see it, and it will affect the video signal.
The Video Cable connects to the motherboard under the Middle Cover, above the F4 and F5 key on the Keyboard. (Left edge of F4 key over to middle of F5 key)
[Middle Cover is Acer speak for Switch Cover. The cover strip above the Keyboard, and below the LCD screen ]
aspire-3100-5100-5600-lcd-cable-dc020007o00-.html
http://www.laptops-we-r.com/prestashop/aspire-5100-parts/109-acer-
Click on the view to enlarge. Top left side connects to the LCD screen. Rectangular Black connector with thick round cable, at the bottom, connects to the motherboard. Small cable coming off at the bottom, connects to the screen Inverter ]
From the motherboard connector the Video Cable routes up under the left Hinge, and into the Display Assembly. It then connects to the screen Inverter, and LCD screen.
From normal opening, and closing of the laptop, repeatedly, the Video Cable may become pinched.
This can lead to loose connections.
It can also lead to damage of the Video Cable.
If the sheath of the cable shows apparent signs of damage, the tiny wires inside may be damaged also.
Stretched/Broken
This means to ENSURE that the Video Cable is NOT the problem, a continuity test needs to be performed on all of the Video Cable's wires. (OHMS)
If an economical multimeter ($5 to $12) is not available, suggestion is to take it down to the nearest 'Mom and Pop' computer store, and have them check it. Labor charge should only be a few bucks.
Video Cable checks out it's on to the screen Inverter, for the diagnoses.
[NOTE*
This diagnoses is for an Acer Aspire 5100 Notebook PC. Uses a single (1) CCFL for a Backlight, and has a screen Inverter. Laptops that use LED's for a Backlight generally do not use a screen Inverter]
Did you test the screen Inverter, or replace it?
http://www.amazon.com/Acer-Aspire-5100-Inverter-PK070005U00/dp/B005F1N5O2
http://www.fonerbooks.com/test.htm
NOTE*
Takes a sensitive multimeter. Read fairly expensive.
Primer;
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor. Suggest start out with your audio turned down ]
It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Acer Aspire 5100 Notebook PC uses a single (1) CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ ]
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer over.
If the screen Inverter is good, the LCD screen is bad.
Replace.
[The LCD screen, and the screen Inverter are a MATCHED unit.
When purchasing make sure you get the correct screen Inverter, or LCD screen ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 09, 2012 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
How to change screen bulb for Acer Aspire 1642zwlmi
I am assuming you are referring to the "back light tube"? If so they are easy to change however rarely the issue. Most likely your lcd screen is dead. Here is a step by step:
Mar 28, 2010 | Acer Aspire 1642WLMi Notebook
My screen on my toshiba laptop screen is going in and out do I need to buy a new scren/
Most likely your issue is caused by a failing LCD Inverter. You will need to have this replaced. Part is available here: http://cgi.ebay.com/Acer-Aspire-One-A110-A150-LCD-Screen-Inverter-B089AW01_W0QQitemZ190363835846QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2c52919dc6
This site explains the process for an Aspire 5100 which can also can be used as a reference for your Aspire One model http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Jan 14, 2010 | Acer Aspire One PC Notebook
Screen change for a acer aspire 6920g
Aug 02, 2009 | Acer Computers & Internet
Update: Acer Aspire 5100 black screen post by daddysangelg.
yes, check first the inverter, then vga cable connection, or the video card...
Jun 07, 2009 | Acer Aspire 5100 Notebook
Need to change the lcd screen acer aspire 5570z
Here is a tutorial on how to change the LCD on a Aspire 5100,
It is basically the same on Acer laptops.
Copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 13, 2008 | Acer Computers & Internet
Acer Aspire 5100 PC Notebook
hi!!!
may be the power option
try to check it!!!
ok go to start
then setting
go to the control panel
click on the power option!!!
Oct 31, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
