Question about GPS
Mazda6 TCM replacement... hi all i am asking a very critical question here.. i have a mazda 6 2003 2.3l 4 cylinder.. But the origin of the car is from signapore.. The TCM is shorting and requires replacement .. However i am not able to surcec the exact part number .. but i can get TCM of 2004 mazda6 in the us for same engine.. will it work?
  • 532 Answers
2004 mazda6 will work for 2003 mazda6.
But go to the authorize dealer and you will get specific part number you are looking for.
Thanks for contacting Fixya.
Posted on Jul 23, 2010
  • Davea Mohammed Jul 23, 2010
    what is happening is I believe mazda retagged and revised these tcm Part numbers so its not showing up on their systems.
    i might just take a chance and see if it works.
We are looking to buy a 2003 Mazda 6 S I was wondering if this engine a V6 has a timing belt or chain thanks Mike
Reading Topic: Timing Chain?? Both the 4 cylinder and 6 cylinder use timing chains. These chains are pretty much service free and should last the life of the vehicle. Borrowed from http://forum.mazda6club.com/mazda6-atenza/121169-timing-chain.html
Jan 11, 2011 | 2003 Mazda Mazda6
Mazda 6 gear 3 jerks and also today had a red engine light.What could be the problem
sounds like a timing belt ready to go or slipped..valve timing off 3rd gear..how many mile belt should be replaced every 60,000 miles..thats a interference motor 4 cylinder is..and you will fruin the motor
Jan 05, 2011 | 2003 Mazda Mazda6
Firing order for 2005 mazda6
This model used 2 engines, a 6 cylinder and a 4 cylinder, here are both.
4 cylinder firing order is 1-3-4-2
Here is the diagram:
Here is the 6 cylinder firing order 1-4-2-5-3-6
Jan 04, 2011 | Mazda MAZDA6 Cars & Trucks
Spark plug wire diagram for 2005 mazda 6
2.3L 4 cylinder? After removing the plastic engine cover, look at the top of the ignition coil.
It should be numbered 1 through 4.
This is plug number 1 on the engine:
Just wire them 1, 2, 3 and 4 to the corresponding numbers on the ignition coil.
best wishes
Jan 01, 2011 | Mazda MAZDA6 Cars & Trucks
I need the 2003 Mazda 6, 2.3 - 4 cylinder main bearing torque specs and sequence asap please.
Fig. Loosen the remaining camshaft cap bolts using this sequence-2.3L (KJ) engine
Fig. Tighten the camshaft cap bolts using this sequence-2.3L (KJ) engine
Nov 09, 2010 | 2003 Mazda Mazda6
2009 mazda6 has no spare wheel
go to your local wrecker and get them to match some thing up as it doesn't have to come of a Mazda (most early Mazda only had 4 stud rims)
other option is to go to a Tyre retailer and get a cheep mag wheel and a cheep Tyre fitted if it is only a spare it dosn't have to look good
Apr 07, 2009 | 2009 Mazda MAZDA6
2005 Mazda6 tranny ****
1. some mazdas had a PCM/TCM update to resolve 1st to 2nd shift shock. the only one who can update the is the dealer. maybe covered under 5 year 100,000kms powertrain warranty.
2, have you ever had the transmission fluid replaced? it could be dirty, burnt, etc.
if it was replaced, maybe it was replace with fluid other than M5 fluid. different fluids have different properties (thickness etc) which could cause serious problems if left.
I would recommend taking it to the dealer for the update and a transmission flush (not a drain and fill) using a flush machine.
Dec 31, 2008 | 2007 Mazda MAZDA6
2003 mazda 6 has a v 6 that is the 3.0 rite the 2.3 was a 4 cylinder rite
yes you are right also easy way to tell is by how many spark plugs you have
Dec 04, 2008 | 2003 Mazda Mazda6
GPS Logo
240 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
