Question about HP LaserJet 1320 Printer
Why is it printong crooked?
I work at an accountants office and we have to print checks for the clients. Well we recently switched the check printer to the HP laserjet 1320 and it prints everything fine except the bank code on the bottom. It prints it at a slant and we heve tried cleaning the wheels and adjusting the paper but nothing seems to work.
  • reginaelwood Feb 13, 2009
    My hp 2401 photosmart all in one printer has started printing on the paper crooked. How can I fix this?
    Problem Solver:
  • 9 Answers
The problem can be with the software program. May be the formating of that particular text has been accidentally changed to italic. Or print the same on a plain A4 paper or slightly bigger paper than the check and see if you get the same problem.
Posted on Jun 20, 2008
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Setting up Terminal Services on Server 2003 at the head office of a client in a workgroup environment, no Domain Controller. The branch office wants to log in through a VPN Router ( Linksys RV042 that has...
Assuming you can connect via Remote Desktop without any issues...
Printing through Terminal services requires that printing be enabled in the Terminal Services Configuration (Client Settings Tab). It also requires that the printer driver be installed on the Terminal server, not the actual printer (as it shows under the control panel) but just the driver. You can install just the driver by going to File/Server Properties under Printers and Faxes ON THE TERMINAL. Install the printer normally on the client machines.
Note: For a printer to work via Terminal services it needs to have a compatible driver (which I believe is called PCL??) So some consumer printers (the ones that only come with Setup programs, not just driver packages) will not work. The majority of HP Officejets and laserjets are fine, as are Brother lasers.
Oct 27, 2009 | Microsoft Windows Server 2008 Terminal...
Printong Photo's Off Memory Card
you should be able to put the card in your printer and press the hp i conn for you printer and they should come up on your desktop
Apr 18, 2009 | Computers & Internet
My Canon MX700 printer prints crooked--did the maintenance too!
Try printing from the rear tray. My printouts from the bottom tray come out crooked, but the ones from the rear tray seem fine.
Mar 01, 2009 | Canon MX700 Office All-In-One InkJet...
HP OfficeJet 7310 printing crooked. New HP cart installed.
There is a back panel that opens up by turning a knob....remove that panel and view for any paper pieces...
keep me posted if this didn't help!
Nov 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Cannot print with pixma 6220D on vista computer
Have you downloaded and installed the latest Vista drivers, available here? If not, uninstall and delete the current installed driver, and delete the icon for the iP6220D from your printers window. Download and install the Vista driver for your printer.
Sep 14, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Printing is crooked on the page...otherwise prints beautifully
Sounds like the print head / ink cartridge is not seated all the way. Open the door and check it. It also may be the wrong print head / ink cartridge. If you replaced the print head / ink cartridge recently, you may have the wrong one for your device. If it is a off brand or refilled print head / ink cartridge it may be damaged or incorrectly identified.
Jun 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Cant print in my network
I am having a similiar network problem, I setup the 2600n on my small-office network, plugging it into an 8 port switch along with a computer and IP camera....then connected the switch to the default router...this worked for a while as my router provided the printer an internal IP, but somehow the IP reset itself to an external IP,and print jobs I send now to the 2600n from my network will not print. I can't seem to access a configuration window to set a static IP address my router will recognize.
Feb 15, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 1320 Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
