At the end of a wash, the following 3 lights are flashing Normal, economy and china. I have a Viking Professional 450 series
  • 15,935 Answers
What is the exact model # please??
Thanks!!
Posted on Jul 23, 2010
  • michel_savoi Jul 24, 2010
    The model is VDB450SS
The lights of my Viking dishwasher VDB200SS are flashing and do not stop even if I reset the unit by pressing start for more than 4 sec. The pump is running when I connect the unit to electric power for a...
Hello Jo, welcome to FixYa.
Based on your post, I suspect you mean the drain pump is running as is common for Asko built machines such as your Viking with this scenario/error. I have good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What this usually means is the control has indicated a overfill. All the indicators flashing is the error code for overfill/drain error.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump or a inlet water valve, so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit activates the pump-out non-stop
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
Oct 17, 2011 | Viking VDB200 Dishwasher
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Dishes not drying properly
You may have it set to an ECO wash (economy)witch may exclude drying cycle at the end to save power.
May 28, 2010 | Viking DFUD042 Built-in Dishwasher
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Viking dish washer won't drain
1) is the hose clear/ not kinked or pinched
2) is it hooked up to a garbage disposal..( was the plug removed)
3) can you hear something in the drain pump?
if all is good the let me know there may be more I can help with..
Aug 30, 2008 | Viking 24 in. Professional Series VUD040...
Viking vud141 - timer does not end the cycle
you can try this number 305-418-0010 they have everythin for viking product and very cheap
Dec 09, 2007 | Viking 24 in. Professional Series VUD141...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
