Xerox phaser 7750 error code 9-456. Canyou tell me what this means, Thanks.
  • 552 Answers
Click on this link at xerox.
Posted on Apr 22, 2008
How do you reset toner counter on phaser 7750? Thanks
On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
Apr 01, 2011 | Xerox Phaser 7750DN Laser Printer
Error Code 9-456
This error code means the life of the black developer is at its end. It is probably time to replace all four developers and the only reset is replacing the engine control board.
The costs will come around 1000usd I recommend you buy a new one.
Jun 18, 2008 | Xerox Phaser 7750DN Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
Xerox Phaser 7750 error code 14 & 15.
try to hold down the on/reset button a few seconds when you power it up ...on most printers this resets them ..about 10 sec it is enough ...
Nov 26, 2009 | Office Equipment & Supplies
Hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Oct 29, 2009 | Xerox Phaser 7750DN Laser Printer
Error code 7-402
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
Jun 01, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 parts
Google " the parts drop" . Call Britt and see what he has. He should have one of those.
I don't work there but you will never find anyone better to deal with.
Ahh here is his phone number 201-387-7776. Tell them Rick said Hi.....
Jan 06, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750
There is a motor in the laser called the polyogon motor, It turns the mirrors in the laser.
It most likely is not starting fast enough.The laser isnt that hard to remove. But if it has failed, it is pretty expensive.
Let me know if you want to attempt to pull it.
Sep 10, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
May 06, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
888 people viewed this question
jasbo
jasbo
