Question about Zenith SY2765S TV
I can't seem to change the channel from Channel 2 to 3 or 4. I don't have the remote. I am trying to hook it up to the VCR, but the VCR requires channel 3 or 4. Please help.
    Problem Solver:
  • 15 Answers
I have a Sony 27" TV. I tried the same thing on mine. I couldn't change the channel either. You will have to buy a cheap universal remote that will have a code on it for your TV.
Posted on Jul 23, 2010
SRU4050 codes
It seems that there is no setup code for this Aiwa device, with this Philips universal remote control. Anyway, try a code search method. If there is a pretested code, this process will help you.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the SETUP button until the red
indicator stays on, then release the SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Code search by Brand.
Lets you search for a code for a specific Brand within
the Code Library for a particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to be controlled.
indicator remains on, then release SETUP button.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((orPOWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
Jul 24, 2012 | Philips SRU4050 Remote Control
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
VCR channel stuck on channel 2.
It won't play on the usual channel 2 or 3. Press 00 on your remote for the vcr.
Mar 14, 2009 | Televison & Video
How to set a remote for a philips universal cl034 for a sanyo tv
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired mode button (TV,VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL UP. If the device responds, no further programming is required.
Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction to forward again.
Jan 02, 2009 | Philips PM3S Remote Control
Lost remote mrd 310
most universals will use this method.
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 29, 2008 | Philips Magnavox Learning Universal Remote
Need VCR codes for Magnavox Universal remote model CL034
Nov 26, 2008 | Philips Magnavox Learning Universal Remote
My remote is driving me CRAZY!!!!!!!
1) Manually turn on the device to be controlled.
2) Press and hold CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3) Press and quickly release the desired mode button (TV, VCR etc.) . The red indicator blinks off once.
4) Press the CHANNEL UP button repeatedly ( up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction forward again.
5)Press and release MUTE to install the code.
Hope it helps~
Oct 27, 2008 | Philips PM435S Remote Control
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Philips Universal Remote SRU2103WM/17
Try this:
Hope this helps :)
Jun 02, 2008 | Philips Magnavox Learning Universal Remote
Symphonic SC3919
most likely your channels are in SAP mode, you need to set them up as stereo via the menu. Remote code should be 044. For VCR. turn TV to channel 2 or 3 then press VCR button
Sep 11, 2007 | Symphonic SC3913 13 in. Combo
Televison & Video Logo
66 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
