Question about Mitel Superset 4150 Phone
How do i set call forwarding to a cell phone #?
How do i set call forwarding to a cell phone # on the Mitel Superset 4150 Backlite?
    Sergeant:
  • 378 Answers
Press Superkey
Press More until the Forwarding softkey appears.
Press the forwarding softkey
press either busy, no answer or always softkey.
if you pressed busy or no answer, press Internal, External, or Both softkey.
Dial the destination number.
Save on or Save off.
press superkey.
Posted on May 01, 2011
How do I change the date and time on a Mitel Superset 4025 phone system?
The time has to be changed in the programming interface of the phone system itself. You cannot change the time from any set other than a 4150 or a super console 1000. These sets can only be used to change the time on a mitel sx200 or icp. This does not work on the 3300.
Oct 09, 2014 | Mitel Superset 4025 Corded Phone...
Good morning, How do I change the time on my Mitel 4150
You need to log in on the main phone ,mitel superset 4150 and 4025 phone help... or if the 4150 is a sub att. you go through the softkeys.you should see the sub menus ,you should also insist on training as it is a pre-requisite nowadays
Best regards
John
Mar 14, 2011 | Mitel Superset 4150 Phone
Either your on-Site system administrator, or your vendor will have to make the change. This is a system wide setting, not just your phone.
I cant setup the caller id for the mitel superset 4150
This is a system wide setting, not just your phone. Your vendor will need to be involved to make this work, provided that the information is being presented by the incoming lines. If you aren't getting the information, you will not be able to see it.
Call history on the other hand, might not be available on your phone... this depends on the type of phone system you have.
Mark
Jan 26, 2011 | Mitel Superset 4150 Phone
How do you put answering message on phone 4150
Your system must have a voicemail system. And your phone must be call forwarded to the voicemail system.
Jan 16, 2010 | Mitel Superset 4150 Phone
Is there any way to turn the backlite on and off on a 4150?
To turn the backlight off disconnect the AC power adaptor.
These phones will not have backlight when the AC adaptor is not connected.
Once connected, the backlight will be active once more
Jul 09, 2009 | Mitel Superset 4150 Phone
How do I set the time on an mitel 4150 and 4025 phone
Need to log into phone system or if the 4150 is a sub att. you go through the softkeys.
May 16, 2009 | Mitel Superset 4150 Phone
Mitel Superset 4150 will not conect
This phone is a digital phone and requires connection to a digital system commonly called a "key system". If you have removed it from where it was connected and tried to use it at home or somewhere else it will not work. Most home or normal phone jacks are connected to your local provider directly and is what is called an analog system. The 2 are NOT compatable without an interface device. If it is connected to a key system then thier is a problem with the port on the Mitel keysystem that goes to the jack you are plugging the phone into and you will need a technician to fix/rewire this onsite. Hope this helps you. A manual for your phone can be gotton here: http://www.octelephone.com/4150user.pdf
Mar 29, 2009 | Mitel Superset 4150 Phone
Ringer
we wants message reset up
Jan 02, 2008 | Mitel Superset 4150 Phone
Mitel Superset 4150 Phone Logo
319 people viewed this question
Top Mitel Lands Phones Experts
Dustin
Dustin
David Payne
David Payne
Marvin
Marvin
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
