Question about Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582
My Generac model 4582-2 is runing with 60Hz on one leg & 120Hz on the other. What's up?
Generac 15000 4582 won't start - seems to be flooded - blowing fuel out of exhaust - carb solenoid checks out but fuel flows into carb even when off
Carb. Sol. Can work electrically but the seat may not be sealing. Would remove and clean. Also place shutoff valve in fuel line and always turn off when storing.
Sep 12, 2017 | Garden
I've recently ordered a Proscan PLED5529A 55" 1080p 120Hz LED HDTV, However, a Proscan PLED5529A-B 55" 1080p 120Hz LED HDTV was sent. What is the difference? One difference i've noticed in the...
Same issue here. I'm debating to send it back as most specs are pointing to the A-B model as being 60Hz. I can't really tell of it's pushing 120 or 60 (ignoring the fact that the screen says 60Hz.) It almost "feels" like it's 120 but can't say for sure. Can anyone please confirm that the "A-B" version is indeed 120 or not? Thanks!
Mar 02, 2013 | Proscan Televison & Video
LCD outputs 120Hz, but only 60Hz when PS3 is connected via HDMI
CODTerroist,
How did you fix this issue??... I need help please
thanks
Jun 22, 2009 | Sony PlayStation® 3 (60 GB) Console
Game plays in 1920/1080p **60Hz**. i have a LED 120Hz TV.
the tv only gives out as much as it can, you cant improve it, srry
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
DOES PLASMA TV HAS 120HZ AUTO MOTION PLUS
This particular model has a 60Hz refresh rate. At this point there are no broadcasts or video sources outside of special labs that can generate enough data to produce a refresh rate of 120Hz. Expect this to become available in a year or so. Please realize that the human eye can not see changes faster than about 30 frames per second. The current standard refresh rate of 60Hz is twice that. The only change you could see (unlikely) would be a slightly smoother flow for fast moving scenes. Typical movement on the screen will not likely see a difference.
Dan
Mar 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
60hz to 120hz
If you are asking if there is a way to make a 60hz tv a 120hz tv, no, there is no way to do that. The clarity is mostly dependent on the signal and the TV. For instance, if you have a 1080P television and are getting a 1080P signal (from a Blu-Ray player or HD DVD), then you should be getting a very clear picture. It will be a little smoother if the TV's refresh rate is 120hz or 4ms as opposed to the standard 60hz or 8ms. If you have a high-def satellite or cable box, you should get 1080i if the channel is broadcasting that way, but you cannot make the TV do something it was not designed to do.
Mar 14, 2008 | Televison & Video
Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582 Logo
104 people viewed this question
Top Generac Guardian Electrical Supplies Experts
Craig Butler
Craig Butler
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
